How to Ford in dash CD changer repair FIXED!!
Old 09-23-2011, 01:38 PM
radmacks's Avatar
radmacks
radmacks is offline
Talking How to Ford in dash CD changer repair FIXED!!
I put together this tutorial after experiencing the no cd, cd full errors. I tried to make the guide simple enough to follow so that the average Joe could complete this repair themselves. This guide is intended for people who are experiencing the common errors and or just want to remove their cds without scratching them.
I have the tutorial in word and pdf but could not figure out how to upload so I posted it on google docs. If someone wants to post the pdf as a direct attachment let me know and I can email it. I did not proof read it after google conversion so easy on the criticism. I'm just trying to put something back after taking so much from this site.
https://docs.google.com/document/d/1.../edit?hl=en_US
Old 11-03-2011, 06:06 PM
akakeester's Avatar
akakeester
akakeester is offline
No criticism at all, but I dont think the google doc link works 100%. Only gets down to separating the unit from the shock cage and then nada. Any thoughts Radmacks? Really appreciate your posting this fix out there!
Old 11-20-2011, 10:25 PM
IslandBlueV10's Avatar
IslandBlueV10
IslandBlueV10 is offline
Hello Radmacks,
I would be interested in a copy of this writeup if you still have it. I would really like to fix my radio. The link you have doesn't show everything.
Thanks.
Old 12-02-2011, 04:39 PM
lost1wing's Avatar
lost1wing
lost1wing is offline
I had found that a plastic worm gear had split, allowing the drive motor to run and not move the disc's. I put JB weld on the gear and shaft assy, and now it is working fine.
Old 12-02-2011, 05:31 PM
IslandBlueV10
Thanks for the reply. Now to try and fix mine.
Old 12-02-2011, 08:27 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
pm sent
10chars
Old 12-06-2011, 06:29 PM
2000silverbullet
Radmack's doc attached.
Reps sent for documenting it!
Old 12-06-2011, 06:46 PM
IslandBlueV10
Thanks For posting the pdf. I know feel more confident in taking mine apart. Hopefully I will get the chance to take mine apart soon.
Old 03-14-2012, 10:01 AM
SLAYER1's Avatar
SLAYER1
SLAYER1 is offline
my wifes 2002 EX battery died & when i replaced it i got the cd error message, should unplugging power to the radio fix this?
Old 03-14-2012, 09:43 PM
IslandBlueV10
It might work, It wouldn't hurt doing it it might reset it, if that doesn't work post back and maybe more will help.
Old 03-15-2012, 05:28 AM
2000silverbullet
I did a quick search for this and it sounds like some guys were able to get it working again by disconnecting the power for a bit while others had to replace their head units. May be time to go aftermarket. Sounds like a tossup though...
Old 03-15-2012, 08:08 AM
SLAYER1's Avatar
SLAYER1
SLAYER1 is offline
talked to an installer at a radio shop last night, he said it wont work but I'm sure they just want to sell me a new head unit, going to try anyway this weekend, my wife doesn't really care about cd's anyway.
Old 03-22-2012, 11:41 PM
mpetry's Avatar
mpetry
mpetry is offline
thanks
Wow, I just came on the forum just to see if there were any people having this CD issue and here I find that this is common! and a fix file posted (I understand, my mileage may vary).
Thanks so much!. I'm going to give this a try this weekend. In the meantime I found that if I loaded a CD, let it spin and return "No CD", then pressed load again for the same CD slot#, it would finally "see" the CD about 80% of time. Slow... but I got by for a while. Now I need to (try to) fix it.
Old 04-21-2016, 01:19 AM
jle70's Avatar
jle70
jle70 is offline
Curious if this will work with all of the in dash cd changer factory radios.
Old 08-01-2021, 11:53 AM
hp-slp's Avatar
hp-slp
hp-slp is offline
The tutorial is great. Thank you. In my case the plastic gears (mainly the worm gear) from the motor which separates the CD layers is completely gone. Does somebody know where I can get the complete gear assembly or at least the single gears?
LOVEMYBIGFORD
12-02-2011 04:43 PM
maticuno
1983 - 2012 Ranger & B-Series
08-22-2004 12:32 AM
Barry M
05-02-2003 08:45 AM
Quick Reply: How to Ford in dash CD changer repair FIXED!!
