OBD2 scan pod thing?
Old 09-23-2011, 12:42 PM
thefnswits's Avatar
thefnswits
thefnswits is offline
a few months back i saw someone post a picture of this scan-pod that told engine temp, trans temp, all that. i thought it was called proscan but i guess I was wrong. any help on what the brand is? thanks!
Old 09-23-2011, 01:05 PM
MCDavis's Avatar
MCDavis
MCDavis is offline
I believe you're referring to the ScanGauge:
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
Old 09-23-2011, 07:26 PM
chuck s's Avatar
chuck s
chuck s is offline
-- Chuck
Old 09-23-2011, 08:02 PM
thefnswits's Avatar
thefnswits
Thanks guys! And chuck that was the exact picture I saw. Is it compatible with multiple vehicles? Like my 1999 f250 5.4 and my 2008 expedition?
Old 09-23-2011, 09:27 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Scangauge II is a much more versatile tool. Runs about $100-130 new
it will read any OBD-II compliant vehicle. So basically any vehicle from 1996-current. Shows 4 gauges at a time.
Old 09-25-2011, 11:19 AM
chuck s's Avatar
chuck s
chuck s is offline
Check the Interceptor (Aeroforce) website. The device is manufacturer and buss specific. This one will work on my '07 Expedition but not '02 Explorer. CAN2 vs CAN data buss. There are specific models for Ford, GM, Chrysler, etc based on the data their systems put on the buss.
This gauge is designed to mount in a pod but I've stopped looking for a nice pillar post pod for my Expedition. Tried one for the F150 and it was unacceptable. I temporarily mounted mine in a corner the dashboard 4 years ago. Still Velcroed there.
The gauge will cycle thru four parameters on both displays for a total of 8 displayed (2 at a time). There is also an alarm that can highlight any parameter. Mine alarms Transmission Temperature. They guys with Mustangs use it as a shift indicator. I typically monitor transmission temperature (trailer towing) and cylinder head temperature. Engine coolant temperature runs flat line just below 200°F with my trailer.
More of a gadget with my 5000 pound camper and 9000 pound maximum towing capacity. If you're towing closer to maximum transmission temperature is a critical thing to monitor.
Note the Green display is blinding at night and inconvenient to dim via the menu. At least on my early model. The Areoforce guys used my Expedition to find Transmission Slip (Trans Slip 2). They reflashed the firmware and replaced my display with Red which is wonderful at night but nearly invisible in daylight. Maybe blue is a good compromise?
-- Chuck
jwill8957
2009 - 2014 F150
09-27-2011 10:13 AM
UGA33
06-16-2010 10:20 PM
MGTMike
1997 - 2003 F150
10-11-2007 12:20 PM
yamaguy
07-15-2007 09:00 PM
sgrol
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-24-2006 04:23 AM
Quick Reply: OBD2 scan pod thing?
