block casting number id
Old 09-18-2011, 12:43 PM
joe f350's Avatar
joe f350
joe f350 is offline
6 9 llf 150598
second row 112 893
i was told this is a 87 motor but i have my doubts so a confired id would help thx u
Old 09-19-2011, 12:07 PM
turbill's Avatar
turbill
turbill is offline
bump i'd like to know how to identify blocks too
Old 09-19-2011, 12:08 PM
joe f350's Avatar
joe f350
joe f350 is offline
me to bill i have my doubts that is a 87 is dosnt have the one pice oil filler neck and if it is a 87 that mean the timing could be way off
Old 09-19-2011, 12:33 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
not sure if this will help,
"INTERNATIONAL HARVESTER DIESEL ENGINES
6.9L and 7.3L Core Identification
6.9L Old Style Block
Block Casting Number:
On left side of block (beneath oil cooler) 1805440C1
Note: Some 440 blocks are truly new style and must be visually inspected by raised donut around the block heater, frost plug (right rear). Old style below serial number 173828.
Visual Identification:
*No counter bored area for block heater
*No defined area on side of block for dip stick
*Thickness of cast iron around block heater 3/8" (.375")
Head Bolts:
*7/16, 12 point socket is used to torque head bolts
*Block tapped with 7/16-14 for head bolts
6.9L New Style Block
Block Casting Number: 1807996C1 Note: Some new style blocks have casting
number 440. Above serial number 173828.
*Has counterbored area for block heater
*Very defined relief area cast in side of block for dip stick tube.
*Thickness of cast iron around block heater 15/32" (.470")
*Latest style (not all new style 6.9) has ribs around head bolts, rear two on left side go from head gasket surface to pan rail - same as 7.3
Head Bolts:
*Same as old style 6.9
7.3L Block
Block Casting Number: 1809000 C1
Visual Identification: *Same as 6.9L new style block
*Head bolt ribs on side of block extend from pan rail to head gasket surface or rear two head bolts left side
Head Bolts:
*1/2" - 12 point socket is used to torque head bolts
*Block tapped with 1/2 - 13 for head bolts"
Old 09-19-2011, 02:00 PM
joe f350's Avatar
joe f350
joe f350 is offline
thanks dd this help some if in reading thing right
Old 11-06-2020, 11:06 PM
roderek's Avatar
roderek
roderek is offline
Where did you find that information?
Where is this from? Do you have the official documentation stating this?
Head Bolts:
Head Bolts:
7.3L Block
Head Bolts:
Old 11-07-2020, 10:48 AM
lonewolf_'s Avatar
lonewolf_
lonewolf_ is offline
Scope Wizard
check the Engine Builder Magazine around 11/01/2006 <<== ok that date was July 07 2006... the PDF date was 11/01/2006
my guess is that post in question came from https://www.dieselbombers.com/ford-8...ease-read.html
or it was just repeated over there
Lukes66
11-19-2010 12:59 PM
dutchie
07-29-2008 10:21 PM
67rangerxlt
10-05-2007 10:38 AM
caterpillar
04-17-2007 07:45 PM
Royson12
02-25-2007 06:58 AM
Quick Reply: block casting number id
