Air filter set-up Okay??
2001 Ranger 4.0 4x4
Ive ran it with 93 octane and put this filter on it & seen NO improvement whatsoever in mpg.
Someone told me that the filter might need to have some kind of a partition around it if Im going to use a cone style filter
I also have the metal tubing to go with it. I can put that on if that is the reason this high-flow air filter hasnt netted me any gains yet in mpg.
Anyone know if this set-up is okay?? Do I need a partition to block off the rest of the motor compartment that way it'll suck cooler air from underneath like it used to??
2 pics
2 pics
1) I have seen many filters increase mpg. You have more power using same amount of fuel, therefore can go further. Mine is not for some reason.
2) I didnt ask what the significance of "partitions" are. I clearly stated WHAT they are used for and asked if my setup required one
2) I explained it. It keeps the hot air away from the filter so more cold air gets drawn in. Cold air is denser. Since the amount of fuel that can be burned is directly linked to the amount of air available, denser air equals more fuel that can be burned, creating more power.
