Minnesota Chapter Join Chapter, Leader: fordpower88
fast idle and winter is on the way
Old 09-16-2011, 07:31 AM
toby tough's Avatar
toby tough
toby tough is offline
hey guys! a newbie here with a question.i have a 92 f150 with a5.0 and a really high idle. i have replaced the tps,map sensor, iac, and temp sensor,but still not fixed.checked all the vacuum lines and also pulled out a lot of hair in the process. i suspect a manifold leak some where under the upper intake. is there an easy way to check it?
Old 09-16-2011, 07:38 AM
dlibson's Avatar
dlibson
dlibson is offline
Get a can of brake cleaner, and with the engine running spray around all the intake gasket areas. If there is a leak, the idle will change when you spray it...
Old 09-16-2011, 08:07 AM
DieselCamper01's Avatar
DieselCamper01
DieselCamper01 is offline
Welcome to the MN chapter and FTE Toby!
deputydog03
04-08-2018 12:03 AM
GroverDill
11-19-2017 04:12 PM
leonharu
07-09-2007 03:52 PM
markcaillier
09-01-2002 03:50 PM
Paul_no
1978 - 1996 Big Bronco
08-13-2002 10:38 AM
Quick Reply: fast idle and winter is on the way
