camshaft sensor
Old 09-10-2011, 10:24 PM
netty628's Avatar
netty628
netty628 is offline
camshaft sensor
I have a 2008 Expedition. Today my engine light came on and I took it to Autozone to get the test run. It came back as a camshaft sensor A bank 2. So my question is, are they hard to replace yourself? My husband was gonna try but he doesnt know alot about cars. I am sure he can figure it out if it is not hard. Thanks
Old 09-10-2011, 11:08 PM
shorebird's Avatar
shorebird
shorebird is offline
Welcome to FTE.
I would like to answer the question however I need to know what motor you have in the Ex.
Is it the 5.4L V-8 or the 4.6L 6 cylinder?
In the 5.4L the camshaft position sensor is located in the front end of each head.
It is held in by 1 bolt.
Buy BWD Camshaft Sensor CSS1643 at Advance Auto Parts
How To Replace A Camshaft Position Sensor (CMP) - YouTube
I would go ahead and change both of them while I was in there.
Old 09-10-2011, 11:12 PM
khadma's Avatar
khadma
khadma is offline
Carpenter Local 745
Remove negative battery cable before removing sensors.
Computer has to go to sleep for at least 15 minutes before
reconnecting battery.
AND it is a safety issue too.
Post your results when the repair is completed!
BTW
Welcome to FTE, netty628.
Old 09-10-2011, 11:15 PM
netty628's Avatar
netty628
netty628 is offline
Hi Shorebird, it is a V8. So with knowing that is this gonna be a difficult job? Thanks
Hi Khadma, thanks for the tips. I will post what happens tomorrow.
Old 09-11-2011, 12:40 AM
shorebird's Avatar
shorebird
Watch the video and figure out if you can do the job.
http://www.youtube.com/watch?v=AKYjp...ature=youtu.be
For me it is simple. For my wife it is impossible.
Old 09-11-2011, 02:13 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Shorebird, the 2007+ Expy only has the 5.4 3v for the motor. Ford didn't continue the 4.6 2v/3v into it the latest version
Old 09-11-2011, 06:10 AM
shorebird's Avatar
shorebird
Duly Noted. Thanks Tylus.
Old 09-11-2011, 02:40 PM
netty628's Avatar
netty628
netty628 is offline
Yay!! It is all fixed. The part cost me $14. The shop down the street said it was gonna cost about $200 to fix cause it will take about 3 hours to fix. Again, my hubby knows really nothing about cars and it took him less than 10 minutes. Thanks for all the help you guys gave.
Old 09-11-2011, 02:48 PM
shorebird's Avatar
shorebird
We do what we can.
If there is someone whose post is particularity helpful There is a way to say thanks.
In the upper right of the post there are two red buttons.
The left one is for "Repping" them and the right is for giving a negative.
There is a blue bar across the top of the thread where you can click on "User CP"
That will take you to your personal account info.
Scroll down and you will see where your Rep points and the accompanying notes are listed.
Old 09-21-2011, 04:45 PM
netty628's Avatar
netty628
netty628 is offline
Well my engine light came back on again today. Only been about 10 days sinces my hubby replaced the sensor. Another guy helped me at auto zone today. Test came up as same sensor A bank 2. My hubby replaced the drivers side sensor. It worked fine up until today. Could he have replaced the wrong side? Thanks
Old 09-21-2011, 08:03 PM
shorebird's Avatar
shorebird
There is the possibility that the sensor has failed.
There may be a fault in the circuit wiring that will show as a sensor problem.
A thorough inspection both visually and doing continuity tests for damaged wiring or connectors is needed.
Sometimes a fault may be in a connector and simply disconnecting then reconnecting it may clear the fault.
A connector may have not been completely reconnected by your husband and it has worked loose.
Happens all the time.
Old 08-03-2014, 05:37 AM
emhoppe's Avatar
emhoppe
emhoppe is offline
YouTube Video shows as Private
Originally Posted by shorebird
Welcome to FTE.
Is there a way for me to view your YouTube video on replacing the BANK1 CMP? I need to replace it in a 4.6L 2003 Explorer due to CEL code P0340.
I am having a tough time (as well as others) finding the BANK1 Camshaft Position Sensor (CMP) ....
Thanks...
MrFunkyOne
17
04-10-2017 03:21 PM
Mr. PC
2004 - 2008 F150
05-07-2010 10:29 PM
earlybirds
Modular V8 (4.6L, 5.4L)
12-27-2007 10:24 PM
splashtm
1983 - 2012 Ranger & B-Series
12-14-2004 08:19 PM
Quick Reply: camshaft sensor
