2000 Expedition AC Compressor/Clutch Noise
I removed the belt and checked both the idler & tension pulley. Both are good. I hand turned the wheel on the clutch assembly and can definitely hear the noise. So does this mean it's just the clutch assembly or could it be the entire compressor?
It's the hub more than likely on your a/c compressor.. I would recommend replacing the clutch/pulley ***'y while you can.
I had the noise, for a month, and it finally locked up on me. Costed me more than it would have if I replaced the clutch/pulley ***'y in the beginning.. Check out my thread.
Title is "Maybe you guys can help me"
