Bypass the fuel relay switch
Old 09-10-2011, 02:39 PM
xxshine's Avatar
xxshine
xxshine is offline
4.9 L. At the switch, cut the yellow wire. Cut the brown wire and hook it up to a keyed positive wire ( a wire that's hot when key is on ). Now if you've disabled some of the smog junk ( like me ), clip the red wire and cap it with a twist nut. The check engine lite won't come on anymore. I think that will disable the injector blower fan too, but i removed that stupid thing a long time ago. Irregardless, the red wire doesn't do anything important anyway.
Old 09-10-2011, 03:41 PM
bashby's Avatar
bashby
bashby is offline
Huh?!?!?!?!?!??!??!?
Old 09-10-2011, 04:31 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Is he talking in his sleep??????
Old 09-10-2011, 08:54 PM
L. Ward's Avatar
L. Ward
L. Ward is offline
Thumbs down NOT a smart thing to do!!
If I am reading right, he is talking about bypassing out the inertia safety switch. NOT a smart thing to do, as that is one of those things that is there for a reason. There is no sane reason to bypass that switch, and if you are in a wreck, the pumps can and will keep spraying fuel. You ever see what happens with an engine fire in a wreck, where 2 people are pinned in a 92-96 stepside and the relay doesnt kick off the fuel as it burns? By the time a rig got there, it was totally involved. Needless to say it was not a good night.
Old 09-10-2011, 09:07 PM
xxshine's Avatar
xxshine
xxshine is offline
When that inertia switch fails, the motor won't start. Then you have to run down the problem and then buy the part. And what if the switch fails far away from home. What are most people going to do. Answer is that they will have the vehicle towed at $$. By taking that inertia switch out, a piece has been eliminated and fewer problem points. I bypassed the fuel relay switch cause i got a bad switch and there's no return on electrical parts. So now i don't have that part to fail, either.
Old 09-10-2011, 09:37 PM
L. Ward's Avatar
L. Ward
L. Ward is offline
Thumbs down Still a stupid thing to do!!!
You also don't have a important safety item on the truck anymore. A few years back, I was travelling on I-95 in Fla and came up on a stepside that slammed into the Jersey barrier and then ran into the woods and caught fire. For whatever reason, the inertia switch did not trip. The driver and passenger were pinned with no way to get out, and everytime we thought we had the flames down, it flared back up, being fed fuel by the pump. we dumped over 100 POUNDS of dry-chem trying to put it out. The last 3-4 extinguisher loads I dumped straight into the cab trying to hold the flames at bay long enough for a pumper to arrive. Unfortunately, we ran out of extinguishers from stopping semi's before the engine arrived. When they did get there the truck was fully involved from the front bumper back to rear of the cab. There was a small dog in the back that I was able to get out when I planted a empty extinguisher thru the rear window and grabbed him out by the collar and tossed him to somebody behind the truck that had been passing me fresh extinguishers. Needless to say, the driver and passenger did not make it (double fatality). Can I say 100% they would have survived if it did not burn? NO, but I can say that the damage to the cab would most likely not have been a fatality scene without the fire.
Additionally, keep in mind, you are not only putting yourself at risk, but you are risking my life and my brothers lives (in addition to anyone you happen to get into a wreck with) as we are the ones who are running into the fray trying to put out the fire and save your @$$. And all because you want to save $25-30 on the cost of a replacement?
Old 09-11-2011, 02:03 AM
xxshine's Avatar
xxshine
xxshine is offline
That's easy to understand. The hard truth is that lots of people bypass the inertia switch. It's a common topic to discuss. What i hear is people put a toggle in between the two wires as an anti-theft device. Hot wire the thing all you want. It still won't start until the hidden toggle is found.
Old 09-11-2011, 07:09 AM
L. Ward's Avatar
L. Ward
L. Ward is offline
Just because people do it doesn't make it smart or right to do. Same as drinking and driving, etc. Putting a hidden toggle switch to make it anti-theft doesn't require bypassing the inertia switch--- you can wire before or after it, or at the underhood relay for that matter. From a liability standpoint, get involved in a wreck that has problems caused by a inoperative switch that has been bypassed, and expect the lawyers WILL own anything you ever owned by the time they are done. In marine applications, have safety switches bypassed and the CG will ticket you on the spot (and tow the boat). It's like anything in life, there are right ways to do things and wrong ways to do things. As I said before, just to save the $25-30 for the cost of a replacement switch? Stupid, stupid, stupid. These items are NOT problem prone (millions of cars use them) and serve a vital purpose. Removing them does not increase power, reliabilty or mpg, which are the main reasons for removing/modding various factory components. Sorry, but you are not going to change my mind on the stupidity of doing a mod like this, and you stand and watch two people burn to death because of a fuel fed engine fire you would be the same way.
1buddy4me
07-27-2014 06:28 PM
xxshine
08-09-2011 06:57 AM
NicksF250
05-24-2008 05:44 AM
Imaoleguy
1999 to 2016 Super Duty
09-23-2005 02:44 PM
Dutch123
1978 - 1996 Big Bronco
05-01-2004 07:05 PM
Quick Reply: Bypass the fuel relay switch
