Spare tire cable lowering trouble!
Old 09-10-2011, 01:28 PM
bigblackmachine's Avatar
bigblackmachine
bigblackmachine is offline
Well, as I was cranking down the spare tire cable to install a spare tire, (my truch didn't have a spare tire, as the previous owner sold me the truck without one), & the cable went down about half way, & then it then started to go back up towards the belly of the truck. I was only cranking counter clockwise the whole time, so does anybody have any idea what I'm dealing with here. Now the cable does'nt come down at all after it went back up to the trucks belly, & it's very hard to crank. Any advice would be greatly appreciated.
Old 09-10-2011, 02:04 PM
shorebird's Avatar
shorebird
shorebird is offline
The cable has backlashed.
You now have it bound up in the winch.
Get someone to pull on the end of the cable while you crank the winch as if to tighten it.
It should come back out with some effort.
When it starts to retract again reverse direction while maintaining tension on the cable.
It may take some work going back and forth with the crank.
Once you get the cable down use some white lube and wipe down the cable.
pdqford
12-21-2010 03:09 PM
RandB
Aerostar
18
09-14-2008 10:14 AM
oldsub86
1997 - 2003 F150
11-08-2005 07:33 AM
Stangfire
1997 - 2003 F150
05-04-2004 01:21 PM
frazier23727
1997 - 2003 F150
01-28-2004 07:20 AM
Quick Reply: Spare tire cable lowering trouble!
