Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
2000 f650 reverse light switch???
Old 09-09-2011, 04:20 PM
pepsiguy's Avatar
pepsiguy
pepsiguy is offline
I work for a local pepsi company here in KS, and I am currently troubleshooting a 200 650 with th ecat engine and allison tranny. The reverse lights do not come on when put into reverse and the reverse alarms no longer functions either. I have tryed new lights, refreshing the ground connection for the alarm, and used test light to check for power going to lights, etc. I have found no power going to lights or alarm.
Does this unit have a reverse light switch that could be bad on the tranny that is not registering that it is in reverse and not sending power to the lights and alarm..? and if so where is it located?
Thanks for any insight...
Old 09-10-2011, 04:58 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
On the transmission there will be some wires. I do not know which one is the reverse wire, so you will need to find a wiring diagram. Use your test light on this wire.
Also, check all your fuses.
Old 09-12-2011, 08:53 AM
pepsiguy's Avatar
pepsiguy
pepsiguy is offline
Thanks. I think that I found it on the drivers side. by where the shifter rod enters the tranny. It has two wires exiting it also. Has fairly large wrench head on it and goes up to back of tranny to a plug. Must be it.
Will try it thanks.
Old 09-12-2011, 06:43 PM
2rangers's Avatar
2rangers
2rangers is offline
if that tranny is an at545 the reverse switch is on right side of tranny you are messing with neutral safety switch reverse switch middle of tranny close to pan
Old 09-14-2011, 03:35 PM
pepsiguy's Avatar
pepsiguy
pepsiguy is offline
reverse light delima
I am not sure which tranny it has. It is the 7.2 cat with an automatic. It has the 26000 gvw, and I did not see allison stamped anywhere on the tranny pan or what have you.
But you said the reverse light switch is on the passenger side of the tranny?
Old 09-14-2011, 06:50 PM
2rangers's Avatar
2rangers
2rangers is offline
should be at or mt tranny tag is on right side reverse pessure switch on same side unplug wires make jumper wire might have to turn key on see if lights work if lights work need new switch it is a normally open switch
brentk71
09-27-2014 08:12 PM
cray0971
08-25-2011 08:46 AM
atccracing
01-12-2011 09:11 PM
Demon345
1978 - 1996 Big Bronco
02-12-2004 11:28 PM
KTExpress
01-28-2002 08:57 PM
Quick Reply: 2000 f650 reverse light switch???
