How big of a motor can I put in a 1994 F150
i was going to replace my rear end gears and its guna be 800 bucks so i want to know how big of a motor i can put in or how can i get it to burnout and get off the line faster i have 331s and want more off the line power and faster acceleration. anyone here from northeast nebraska with bigger than a 302 motor for sale ? i want to keep it computered but i want it louder and a friend has a carbed 351 and it sounds ****ty. i want at least a 351. let me know
Here we go again!!!!!!
https://www.ford-trucks.com/forums/1...end-gears.html
Before anyone else wastes their time with this 14 year old know-it-all.
Yeah for $800 you should be able to help that 302 out, where you might be hard pressed to swap in a 351 at that price. I got lucky and was able to put in a slightly used 351 long block with new roller timing set, new water pump, and new gaskets for about $550, but I was just swapping one 351 for another (and the replacement motor was only $100). From what I've read on here, long tube headers, new cam (search Conaski's threads for specific suggestions), higher ratio rocker arms, timing bump all help.
First off, make sure what you have is running tip top, a modded worn out motor is still a worn out motor.
Still not sure why everyone wants to listen to a loud truck motor though.
But damn, thats a steep price on a gear swap, I would've thought more like $500ish. My local shop said it would be about $700 to fully rebuild my 8.8 with a new ring & pinion.
EDIT: Just skimmed the link to the older posts about burnouts. Sell the truck and buy a crotch rocket, natural selection is sped up on those toys.
cus they want to annoy the neighbors or if its on a farm take it to the city and annoy the locals and get the police to look his way and give him tickets?
as for the crotch rocket, why not just play with TNT or nitro glycerin? best toys for natural selection right there....
First off I would reccommend spelling out all your words this is a forum not a text message. Second, I would check junkyards for a complete rear axle with higher gears, that should only run you a couple hundred dollars (I am assuming you're a 2x4). Third, it is typically cheaper to sell the truck and get one with a bigger motor in it than to go through the hassle of an engine swap.
how bout this...best way to make your wheels smoke, guaranteed or your money back!!!!! Trust me it works!
Honda Civic Explosion - YouTube
