two different size boxes, bolt up to two different size frames, with two different size pitman arms and sector shafts. You'll want to find one that says it's from an F1 to be sure you have the right one if it's an F1 pickup you have. I provided a link to where you can buy an F1 pitman arm.
If you're looking for an F-1 pitman arm, why does your post title reference F-4-F-6 pitman arm?
He's looking for an F4-F6 pitman arm on the F-1 trucks! Hence the problem he's having...... He needs to start looking at F4-F6 trucks and I imagine his problems will go away..
Sorry couldn't resist; Thanks Wayne
Let us know what your looking for because I've got a sneaking suspicion somebody on here can help you out with whatever it is you need^^^^^
Several of us, myself, Josh and Wayne, may have what you need, i.e. F1-F3 and/or F4-F6 pitman arms. Just need to know for which model truck you need it.
EDIT: Here are two complete front suspensions from an F1-F3 that contain the pitman arms.
