P0278 Cylinder 6 Contribution/Balance Fault
Old 08-30-2011, 06:36 PM
fordpride's Avatar
fordpride
fordpride is offline
P0278 Cylinder 6 Contribution/Balance Fault . What is this telling me bad injector,bad wiring, or is this a IDM problem.
I'm pretty sure i know the answer to this
Old 08-30-2011, 07:44 PM
plgebbia's Avatar
plgebbia
plgebbia is offline
Probably bad injector, but definately check the wiring first.
Does it have a noticable miss?
Old 08-30-2011, 07:51 PM
Action4478's Avatar
Action4478
Action4478 is offline
If the wring and the IDM are not suspect & a compression test is good ,I would then suspect the injector ..
Old 08-30-2011, 08:34 PM
fordpride's Avatar
fordpride
I wouldn't say it's a miss but you can feel a rough spot in the idle about ever two seconds
Old 08-30-2011, 08:38 PM
fordpride's Avatar
fordpride
I changed the UVCH and pig tails out to the SD style about 3 months ago I'll have to re check my connections.
I have a spare IDM that I'll try for shlits and giggles.
And I'll try my spare CPS just to see if for some reason it helps or moves to a different cylinder
Old 08-30-2011, 08:41 PM
fordpride's Avatar
fordpride
I did notice this say I'm going 65 mph and give a little go pedal to pass it will act like it has no power till I really get on it. Im gonna pull the chip tomorrow and go from there
Old 08-30-2011, 08:58 PM
fordpride's Avatar
fordpride
Ok i did another CCT and when it gets to that injector and shuts it down you can defiantly tell that the engine doesn't really change that much not like the rest of them.
Jim do you take blood as payments. LOL
Old 08-30-2011, 09:01 PM
Action4478's Avatar
Action4478
If the engine doesn't change that much ,its not the injector ...
Old 08-30-2011, 09:04 PM
fordpride's Avatar
fordpride
When it does the CCT does it do them 1-8
Old 08-30-2011, 09:22 PM
fordpride's Avatar
fordpride
If not the injector then what am I looking at
Old 08-31-2011, 08:01 AM
Action4478's Avatar
Action4478
Make sure the Wiring is intact, & Ohm the injector solenoid first ..
Old 08-31-2011, 08:50 AM
fordpride's Avatar
fordpride
Will do. I did a buzz test and it passed I also did a WOT run and I normally hit 24 psi I'm down to 18-20psi
Old 08-31-2011, 01:59 PM
fordpride's Avatar
fordpride
To the TOP for any more ideas
Old 08-31-2011, 02:09 PM
Action4478's Avatar
Action4478
How many miles on your injectors?
Have you observed them while the engine is running ?
Old 08-31-2011, 02:13 PM
fordpride's Avatar
fordpride
201,xxx not yet I want get to really rip it a part till this weekend just trying to get a list of things to check when I get off. I'm gonna pull the chip before I leave work
Quick Reply: P0278 Cylinder 6 Contribution/Balance Fault
