1966 power steering
No replacement parts are available for Bendix P/S except the master seal kit (and then only from obsolete parts vendors).
If you can find one...figure 100 bucks EZ.
1966/68 F100/250 2WD / 1969 F100/250 2WD before serial number D96,001 used Bendix P/S.
1969 F100/250 2WD & F350's from serial number D96,001 used Ford (Saginaw) P/S, which was then used into the 1990's.
There are 1000's of posts here on FTE that explain how to install Ford P/S on these trucks.
I read a ton on this issue when my steering gear went out, and one thing I can tell you is all the post say the Power Steering column is slightly shorter, and therefore you have to replace the column. That and the Bendix issue convinced me to abandon that idea. I replaced or rebuilt everything in my 66 from the wheels to the steering wheel, and my truck now drives like a dream. I cannot believe that manual steering can be this easy to drive. I guess I never drove a manual steering box that wasn't half trashed. I drive with one hand most of the time, and I have 3 on the tree. It changed my trucks drive ability about 99%
Agreed! I rebuilt mine, and it does drive so easy that I don't see the point in having power steering... It really is a testament to the design of the period!
Yeah I can understand Power steering if your teenage daughter, or grandma is going to drive it. I tow my boat, and toy hauler with my truck, no problem, and I live by the beach, so parking can be tough, and I have no problem with the manual steering, nor do either of my kids. So put your money where it is needed more! As long as you maintain your steering properly, it will take care of you. As John (Jowilker) said "You don't get much assistance from power steering on the highway, but where it shows up most is at low speed!"
Drove w/o it...and some a those old piles of misery grandma's drove had massive 18-24" wheels, rudimentary front suspension....steered worse than any Slick.
IMO, you don't need P/S unless you do a lotta parallel parking. With properly inflated tires and with steering/suspension up to snuff, even kiddies can drive w/o it.
The main reason I'm interested in P/S is that I end up doing a lot of parking in tight parking lots when I take the truck out. It's a long bed, which makes it worse than most. Some lot aisles are only 25 feet wide or even less. I can armstrong it, but then the steering wheel itself suffers. I've put more than a few cracks in the 2 I've had on it. It'd be nice to 'one-finger steer' it, especially in stopped, tight manuevering situations.
I think we can all agree, that to put power steering in requires a replacement steering column, and gear, and all the power items and mount brackets. For some people all the work is worth it, for others it is not. I am a near purist in my truck. It didn't come with power, so I won't add it now.
