Question for those whom boxed their Frame
I have finshed installing the Front No Limit IFS and Rear 4 bar and now ready to move on to boxing the entire frame. I have a question for those who have done this and ran the wire thru conduit/pipe where did you start and stop your run so the wires enter and exit at the right places? One long run from the front of the cab to the rear or multiples. I am trying to plan everything out before I weld the plate on. If you got pictures that would be great.
Thanks
Kelly
Thanks
Kelly
Thanks
Kelly
Thanks
Kelly
well, there should be very few wires going down the chassis, 5 in a normal environment..
park,
brake
turn * 2
fuel sender
I took my wires out thru the top of the tranny tunnel, across the bottom of the cab floor (welded a small angle iron to wire tire the wire bundle to)
and then split at the chassis.. some forward, some rear. all on the drivers side
now, I also have an electric fuel pump, and the wires for the airbag control modules (2) also come thur the drivers side
the fuel pump is on the passenger side , as is the air pump.
these are powered by direct feeds from the battery also on the passenger side. both are controlled by waterproof relays mounted next to the crossmember/chassis intersection.
so I have wires that split off at the rear cross member (where the normal parking brake cables attach) on both sides.
I did not box all the way, but these are the kinds of things you will need to think about if u run the wires inside. Make sure that the tubing is big enough to push and pull a fish wire thru in case u need to repull wires later.
Sam
I am very pleased with the No Limit IFS and 4-bar. Very solid construcion and heavy duty design. As many others have stated, the instructions are poor, but the Video is a big help. A call to the tech line was the answer to my questions, but they really could take some time and write some professional instructions.
I fully boxed my frame, but I didn't run the wires inside. Most of the wires and plumbing are behind the cab anyway where you can't see them and I didn't think it was worth the effort. Make sure you weld nuts inside the frame where the running boards bolt on, or cut access holes. Also note, your frame may spread slightly from welding the plates. I read about this after I welded mine and couldn't get my tranny crossmember to bolt back in.
http://www.northerntool.com/shop/too...7274_200237274
Sam
________________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Darkside
"Happiness - 3 pedals and a 5 speed"
Hey Kelly, I have done the conduit inside my frame and have picture's of it in a thread a couple months back. https://www.ford-trucks.com/forums/1...-my-frame.html
I have not made it much further than the pictures due to working long hours at work. I cant tell you if mine are in perfect locations yet but you can check it out.
5thwheel-in
1999 to 2016 Super Duty
08-30-2011 06:32 PM
rocketfootballer
03-13-2009 06:47 PM
HYPO
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-09-2008 05:35 PM
