*TV MOUNT FOR RV*
*TV MOUNT FOR RV*
Am looking for a flat screen mount for a 24-32" flat screen that I can install in my 07 Arctic Fox. It wasn't built for a flat screen, it has a space for a 25" CRT TV just inside the door. Don't have any wall area I can use but am trying to find a articulated mount I can screw to the wall above the counter where the CRT goes.
My question is, will an articulated mount take the bouncing of a traveling flat screen (24-32") when it is folded back?
Or, does anyone else have any ideas? Can't use a regular wall mount as the need to have a the clearance to bring the TV out a bit from the window. Maybe a cabinet mount? There is a cabinet above the area where the CRT sits. Again, will those mounts take the bounce of the RV moving?
Thanks for any replies!
I would probably try to find out what the RV manufacturers use. There is a flat screen mounted on the wall of my rear bunkhouse, and it is on there very securely. I don't think I would trust one of those articulated mounts unless it was made to handle the abuse of riding in a towed vehicle, and even then I would be skeptical.
both of my flat panels are hard mounted on the walls so they don't move.
I have seen some that are mounted on a pedstal and then when unlocked can spin around.
Maybe that would be the answer. Take a look at some of the RV's and 5er's that have the tv that spins around from the bedroom to the main living area and maybe that could be used.
I used an articulate mount for several years in one of our motor homes without a problem with a 22" set. I just made sure to collapse it all the way back when traveling. I have also used one and just took the TV off when we went down the road in our travel trailer. It is pretty easy to slip the TV off the mount.
Steve
Steve
I got my articulated mount at Sams Club. Heavy duty mount, no problems at all with vibration. It also tilts up and down something like 20 degrees, -5 to +15. $50 which isn't bad from other prices I've seen.
Found a link, OmniBasics Full Motion Mount for 19" - 47" TVs - Sam's Club
on
1 Post
I use an articulated mount but wouldn't move the camper without taking the TV off the mount. I wrap it in a small blanket and secure it under the bed. I bought 2 of them and rigged up one to work outside under the awning. I installed the mount in a storage locker, connected cable to the camper system, open the door, swing out the mount, drop the TV into it and kick back. So far no issues.
Here is a place that might have something that will work for you. You can do some searches yourself because my search may not have gotten all of them.
Search results for articulated TV mounts
Perry
Perry
Of course, just using the foot is simple enough and cheaper.
Steve
