Speedometer/Vacuum tube which holes thru firewall?
Hi All,
I'm doing the under dash stuff and it's been enlightening.Who would have known there was a filter in the vacuum motor?
So now I don't know which holes in the firewall to use for which one.I had nothing to go by and can't find a picture of the firewall.
Any advice would be greatly appericiated.
Thanks
Cheers!
Thanks
Cheers!
See if this helps. The speedo cable and the choke and throttle cables come through together through the large hole near the center at the indent of the firewall. There's a grommet available to seal it up.
The vacuum hose comes through just above there, a little to the right. You can see it going down to the carb.
guindian28
13
01-29-2024 10:07 PM
rthenry145
18
07-27-2018 03:13 PM
Keymaster
01-01-2018 10:23 PM
Eallend7
29
11-17-2012 10:18 PM
thisspaceleftblank
06-08-2004 09:39 AM
