Do Mustang GT wheels fit on a 56 F100?
Old 08-26-2011, 05:50 PM
HEAVY100's Avatar
HEAVY100
HEAVY100 is offline
I was wondering Do Mustang GT wheels fit on a 56 F100? I wanna buy a used set .
Old 08-26-2011, 06:05 PM
95stepside's Avatar
95stepside
95stepside is offline
does your truck have the stock axles?
if yes, then no they dont firt without adapters
Old 08-26-2011, 06:08 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,423 Likes on 1,379 Posts
What year Mustang wheels are we talking about? In addition to the bolt pattern being wrong, the offset on the newer wheels (94 and up) are extreme positive, similar to front wheel drive. Chances are they won't work for you.
Old 08-26-2011, 06:33 PM
HEAVY100's Avatar
HEAVY100
HEAVY100 is offline
what other stock wheels would fit on stock axles ?
Old 08-27-2011, 01:21 PM
eman92082's Avatar
eman92082
eman92082 is offline
What he said - They won't, GT Wheels are crazy positive offset.
Old 08-27-2011, 02:15 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No 1965/2011 Mustang wheels will fit an F1, F100/150, Bronco or E100/150.
5 lug wheels on a 5.50" bolt circle pattern: 1948/52 F1 / 1953/79 F100 / 1966/96 Bronco / 1975/96 F150 / Some 1980/83 F100 / 1975/2011 E100/150.
Some 1980/83 F100's have 5 lug 4.50" bolt circle wheels. But wheels from Passenger Cars with a like pattern will not clear the F100's disc brake calipers.
Old 08-27-2011, 02:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Ford pickup truck wheels thru the '70's used the 5 on 5.5" bolt circle, and used similar offsets. I think it may even go past that, as I recall '80's (big) Broncos used that b.c. and many of them were aluminum.
Old 08-27-2011, 02:38 PM
NumberDummy
1977: Ford introduced Styled Steel & Aluminum Wheels for F100/150's & E100/150's, Bronco's got 'em in 1978.
These wheels and variations of both were used thru 1983 on F100's (*), thru 1996 on F150's and Bronco's, thru today on E100/150's.
These wheels use 3 expandable anchors to retain the hubcaps, which are plastic chrome or black.
The holes for these anchors are within the bolt circle (the anchors are just hand pressed in). 3 chrome or black screws then thread into the anchors.
Steel anchors are used with steel wheels, nylon anchors with aluminum wheels.
* Some 1980/83 F100's have 4.50" bolt circle wheels, some have 5.50" bolt circle wheels.
See post #6 for the bolt circle patterns.
GreenGorilla
05-02-2013 08:30 PM
Yellerfurd
10-18-2012 11:03 AM
ROCKY1956
04-11-2011 09:44 AM
fordxxx
05-13-2005 08:11 PM
79 posi
General Automotive Discussion
01-23-2005 07:35 PM
Quick Reply: Do Mustang GT wheels fit on a 56 F100?
