Fuse Box Slot 29 - Customer Access?
Old 08-22-2011, 01:48 PM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
Question Fuse Box Slot 29 - Customer Access?
I'm wiring some lights onto my rack on the bed and want to tie them into the fuse box, so I'm looking for a slot that is already wired but not used, and I see #29 is "Customer Access."
Does anybody know what this is?
also, does anybody have a list or diagram that has the color codes for the wires/fuse numbers?
Old 08-30-2011, 08:48 AM
Rose Clifford
anybody?
bump to top
Old 08-31-2011, 01:01 AM
4inchlovin's Avatar
4inchlovin
4inchlovin is offline
heres a bump for ya...
Jim has really good wiring diagrams
Old 08-31-2011, 06:41 AM
Rose Clifford
I just need a fuse that has power, im close to saying screw it and just wiring it ghetto style
Old 08-31-2011, 07:00 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
He!! John, i'd wire it from there. Gotta fuse, plugs' powered up, nothing else is ran from it..id say go for it. I might just find this #29 plug, and re-wire my gauges from it.
Old 08-31-2011, 07:06 AM
Rose Clifford
my problem is figuring out which wire it is behind the fuse box. I have a couple of options on my truck that werent used, like heated seats for example....heated seats is a 30A fuse so it's overkill, but even if I did want to tap into a 10A fuse that wasnt in use I wouldnt know which wire it is.
What's the process behind taking the fuse box apart? I dont want to get too deep into it, burning something out would really tick me off.
Old 08-31-2011, 07:16 AM
timmyboy76's Avatar
timmyboy76
Old 08-31-2011, 07:53 AM
Rose Clifford
Yes except I don't think that would fit under the fuse box cover
Old 08-31-2011, 08:10 AM
wuttrd's Avatar
wuttrd
wuttrd is offline
fuse
that is exactly what i used for my on board air. and it does fit under the cover in the cab fuse box.
Old 08-31-2011, 08:22 AM
Rose Clifford
Interesting, looks like I [you] just found my solution....good thing there's an autozone 1/4mi away from my office!
Thanks,
I still can't believe nobody knows what the deal is with fuse 29, and that nobody has chimed in about the wire color codes.
Old 08-31-2011, 08:31 AM
wuttrd's Avatar
wuttrd
wuttrd is offline
i think that it is # 11 under dash that i used. i want to say it is for wiper and and wiper motor.
Old 08-31-2011, 10:21 AM
Rose Clifford
i found this, but the fuse numbers don't match up
2003 https://www.fleet.ford.com/truckbbas/non-html/2003/bb_pdf/200-202.pdf
2002 https://www.fleet.ford.com/truckbbas...l/2002/278.pdf
here is the manual i go by for my 03 7.3L
http://www.motorcraftservice.com/pubs/content/~WO3F23/~MUS~LEN/36/03f23og5e.pdf
this guide is similar, for the 02...to make sure there is no 6.0 / 7.3 confusion
http://www.motorcraftservice.com/pub.../02f23og5e.pdf
FD5150
12-11-2008 08:18 PM
Bowcop
1999 to 2016 Super Duty
16
10-18-2008 01:22 PM
Spotty
1997 - 2003 F150
06-26-2007 05:02 AM
cubman61
12-23-2006 01:34 PM
scottNgio
02-11-2006 04:49 AM
Quick Reply: Fuse Box Slot 29 - Customer Access?
