Computer Chips & Tuners
SCT tuner question
Old 08-19-2011, 06:31 PM
02ranch250's Avatar
02ranch250
02ranch250 is offline
SCT tuner question
a friend of mine has an SCT tuner and his truck messed up and he said he would give it to me. I was wondering if anyone here would know if it would work as it is now or if i would have to get it reprogramed. The truck it was bought for was an 08 Ford F-150 with the 5.4 and my truck is an 02 F-250 with the 5.4. Any help would be appreatated
Old 08-23-2011, 05:10 AM
megawatt00's Avatar
megawatt00
megawatt00 is offline
What is the model number of the unit? I would cross reference it to see if it will work.
Old 08-29-2011, 07:06 AM
tex25025's Avatar
tex25025
tex25025 is offline
I would imagine that it would be able to load tunes for both vehicles, but you would need to get different tunes for your vehicle.
Old 11-16-2013, 05:04 PM
Fraree's Avatar
Fraree
Fraree is offline
Lightbulb Superchips 1705 max micro Tuner
I have a similar question. A mate gave me his 1705 Max micro tuner as he sold his truck a while back.
I've read in the paperwork accompanying the tuner stating the unit can be "Vin locked". I have plugged this unit in, as per instructions and nothing ! So the question is, what now?
Old 11-20-2013, 07:37 AM
tex25025's Avatar
tex25025
tex25025 is offline
Define "nothing". Nothing shows up on the screen, no instructions as to either load, unload, or a msg that shows that it's vin locked?
If he didn't return his truck to stock, there is very much a chance that it is vin locked to his old truck. You have a couple of options. 1. Pay the company to unlock the device. 2. Use it as a code reader only or 3. Toss it and buy a new one.
Old 11-20-2013, 12:16 PM
Fraree's Avatar
Fraree
Fraree is offline
Unhappy
Nothing means nothing as if it was not even plugged in! Superchips reps in Australia doesn't touch that model, the ford dealer that sold it to my mate a few years back doesn't want know about it either! I'm waiting for a response from the parent company to respond. Don't really want to spend a $1k for a new one
I'll have to contact the original owner to see if the truck was still set up with the settings when he sold it.
Old 11-20-2013, 12:51 PM
tex25025's Avatar
tex25025
tex25025 is offline
Only thing you can do is check to see if the fuse is blown to the OBD-II port. If it is, then that's a simple fix, if not, then you have a paper weight, if Superchips won't do anything for you over there.
Ford dealer really shouldn't have sold it to your mate to begin with as that would null and void the factory warranty on it from the get go. Probably why they don't want anything to do with it now.
Old 11-22-2013, 02:00 AM
Fraree's Avatar
Fraree
Fraree is offline
Red face
Had a good response from Scott the Superchip man on this site, with the most probable reason for the unit not working. Apparently it is reliant on power from the 12 volt outlet (cigarette lighter) Believe it or not, I have 2 in the dash and neither is working . Looks like that'll be the next item to repair
Old 11-22-2013, 06:23 AM
tex25025's Avatar
tex25025
tex25025 is offline
Like I said, blown fuse. The OBD-II port is reliant on the same fuse as the ciggy outlets.
Technically, I think you only have one that's setup as a true ciggy port and the other is a direct feed to the battery even when the vehicle is off.
<object style="position:absolute;z-index:1000" type="application/x-dgnria" id="plugin0" height="0" width="0">
</object>
Old 11-24-2013, 02:06 PM
Fraree's Avatar
Fraree
Fraree is offline
</object>
OBD-II port ? I just need to know where the ciggy lighter fuse is located? This truck has more electricals in it than a christmas tree
Old 11-24-2013, 02:21 PM
tex25025's Avatar
tex25025
tex25025 is offline
They both use the same fuse. It's location is in the manual.
</object>
Old 11-24-2013, 02:26 PM
Fraree's Avatar
Fraree
Fraree is offline
Red face
</object>
I'm in Oz, manuals for F series trucks are rarer than these trucks are here
Old 11-24-2013, 04:35 PM
tex25025's Avatar
tex25025
tex25025 is offline
Well, based on your profile that shows a 2001 truck, I would go through this site to the respective sub forum for your year/model/engine and ask in there, if someone could send you a diagram of where to look.
Or, try google (either their regular search or image search) and see what that shows up. I have a 2006 with significantly more electronics, so I doubt my diagram would work in this case.
</object>
Old 11-26-2013, 03:11 AM
Fraree's Avatar
Fraree
Fraree is offline
Cool
Found the manual, (we call it a handbook outside the USA) to see where the fuse is. Slot # 3, the fuse won't stay in There isn't anything hooked up in the fuse panel, unbelievable! Why would this vehicle have a different wiring system than every other F250! I could do a Wally Binghampton (McHales' Navy) !!
Old 01-08-2014, 02:12 AM
Fraree's Avatar
Fraree
Fraree is offline
Question Power to the connection?
I have power to one of the 12 volt outlets but no fuse in the fuse block. This vehicle was exported as an "incomplete vehicle" so an ID plate says on the door frame.
The question is, where the tuner/chip devise plugs into, (which I have the connection under the dash) which wire can I hook power to or hotwire, to power up the Max Micro Superchip 1705, so I can set up the "tow" mode? This is the main purpose for use of this vehicle.
Quick Reply: SCT tuner question
