1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Changing engine size in 1961 F100
Old 08-19-2011, 01:36 PM
eddie5280's Avatar
eddie5280
eddie5280 is offline
I have a 1961 F100 that needs a new engine and clutch. Is it possible to replace the 292 with a 312 engine without any modification or major changes? Also where can I purchase the new engine, what websites, stores etc. would be a good source for finding a new engine? Can I upgrade to a 4 barrel carb instead of a 2 barrel? I will replace the clutch at the same time - where can I find one that will work for this truck? Thank you for your time.
Old 08-19-2011, 08:29 PM
spurredon's Avatar
spurredon
spurredon is offline
Why not just rebuild the 292?
Old 08-21-2011, 08:38 AM
eddie5280's Avatar
eddie5280
I could rebuild it also. Do you think that is a better option? I just thought replacing the engine would be a faster, better and a little more econimical solution. What are the advantages/disadvantages of rebuild vs replace?
Old 08-24-2011, 07:37 PM
Bushbee's Avatar
Bushbee
Bushbee is offline
In this situation, since the Y-block Ford has not been produced in a gazillion years getting a used running engine could be a big gamble, unless it is a reputable shop that either built it, or knows who built it. Good machine shops can be hard to come by. Especially those that know the ins and outs of a Y-Block Ford. If you take yours to a good shop that is familiar with Y-Block Fords you really can't go wrong. It will probably be more expensive up front, but a good rebuild, taken care of with proper maintenance can be well worth it. Not sure what part of the country you're in, but there is a shop in Englewood, Colorado (Denver area) that does phenomenal work, and the owner/machinist knows every Ford motor like the back of his hand.
Old 08-29-2011, 05:06 PM
jhooch's Avatar
jhooch
jhooch is offline
Finding a 312 is going to be the tough part. These were used in T-birds and cars. Dimensionally they are the same as your 292 (and 272) so the swap would be easy. Check around on Ebay and Craigslist, maybe Hemmings Motor News. Like the above post said, when buying a used or rebuilt engine, do everything possible to make sure the source is reputable.
Old 08-31-2011, 04:54 PM
fordman67's Avatar
fordman67
fordman67 is offline
I have not looked in a while but I sold a 57 312 ecz main cap proper and verified engine. It was torn down and in excellent condition only needing gaskets,rings,bearings. it went for 925 on ebay. I could not believe it went that high.I kind of wish I has reassembled it and put it back in my truck....
Jonesy0027
01-07-2013 01:54 PM
praisethelowered17
05-03-2012 02:07 PM
SGTdirtybum
Texas Chapter
03-16-2006 03:28 PM
DanMan7
09-30-2004 02:44 AM
StantheCowboy
21
10-23-2001 09:28 AM
Quick Reply: Changing engine size in 1961 F100
