how to replace steering box?
Old 08-15-2011, 03:21 PM
ravens fan's Avatar
ravens fan
ravens fan is offline
hey goys i have a 91 150 im wondering what the best way to go about doing this is, do i go at it from the bottom and undo it? it seems pretty simple but is there anything i should know about doing it, got my reman steering box today... mine old one is hard to keep between the lines lol
thanks!
Old 08-15-2011, 03:47 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Old 08-15-2011, 04:41 PM
Slip ford man's Avatar
Slip ford man
Slip ford man is offline
I hope that you are strong...heavy as heck one handed, other hand busy starting the bolts, and a awkward position under the truck...be very carefull not to cross thread the bolts, soft cast/threading's in it..
Old 08-15-2011, 05:05 PM
ravens fan's Avatar
ravens fan
thanks guys and yeah im gonna have my brother help....i couldnt believe how heavy it was when i got it today lol
Old 08-15-2011, 05:23 PM
ravens fan's Avatar
ravens fan
is the pitman arm puller a must need? ir is there another tool that can be used?
Old 08-15-2011, 06:04 PM
bladez51's Avatar
bladez51
bladez51 is offline
I have never done this job, but I understand that the Pittman arm can be a bear to remove. You will most likely need a good puller and it would not hurt to have a torch handy just in case.
A friend of mine who's been through these jobs suggested putting a 2x4 across the engine bay under the hood and tie the steering box from it so it does not drop when you remove the bolts. Also you can use it with a pulley or similar set up to hold the new one while you bolt it back on.
I might try doing it to my truck too. Those things seem to wear out pretty damn quickly. My truck only has 79K miles and it already shows signs of steering play
Old 08-15-2011, 09:11 PM
ravens fan's Avatar
ravens fan
where can you get these pullers at? would napa have them? and i know what you mean mine has an excuse though with 233,000 miles and big tires lol
Old 08-15-2011, 09:25 PM
Encho's Avatar
Encho
Encho is offline
How about internet? the one i used costs around $19, and even less. The puller is a MUST, there are some conical ones which are a little pricier but apparently work even better. Get the K/D tools brand, they're very tough.
Old 08-15-2011, 09:40 PM
andym's Avatar
andym
andym is offline
You can rent or buy one, but it's a requirement. There is no way you're getting the old one off without one. If you are a strong guy you can hold the box up with one hand and thread the bolts in with the other. I did it but my chiropractor was pretty PO'd at me.
Old 08-15-2011, 11:50 PM
ravens fan's Avatar
ravens fan
thanks guys,, ill prob ask a mechanic i know with a garage if he has one before i go out and buy one
Old 08-16-2011, 10:49 AM
Freightrain's Avatar
Freightrain
Freightrain is offline
Azone will rent it for a small deposit, like $20 and you get it back when you return it.
Just did my '89 F150. Ya, it's a bear to hold up there and get the bolts started. Another set of hands would be great(if you find a set). I got it wedged up in there and wiggle a bolt in. Yes, don't cross thread it as it will likely strip the box holes out. Be careful.
xringonly
67
01-17-2014 08:05 PM
zakk
31
05-27-2011 10:29 AM
browntown3
1999 to 2016 Super Duty
04-26-2009 08:25 AM
workingdog
07-10-2008 07:19 PM
katdon2001
03-15-2004 11:23 AM
Quick Reply: how to replace steering box?
