code p301 misfire on cylinder 1
Old 04-02-2003, 10:30 AM
kart17's Avatar
kart17
kart17 is offline
Hoping for some help.99 f150 4.2 v6.Truck has been to ford dealer.They replaced plugs and wires.The truck has also been to another shop twice but i still get the code.I have replaced the coil pack and done a test on the egr valve as suggested on this forum
which tested fine.The one shop say if the use a little propane the engine smooths out.The miss is the worst at cold start time but
is there all the time.Once in a while i will get a backfire from the
engine compartment.If you remove the plug cables from the coil pack one at a time the number one coil seems to be firing a lot stronger that the others.Any ideas?
Ron
Jose A.
Aerostar
04-11-2014 12:35 PM
chrischaugen
1997 - 2003 F150
02-13-2014 01:07 PM
ward107
12-05-2012 03:08 PM
ziggy55
1983 - 2012 Ranger & B-Series
04-04-2010 05:26 PM
Superdave
1999 to 2016 Super Duty
20
06-12-2009 11:13 AM
Quick Reply: code p301 misfire on cylinder 1
