'51 F4 project
#1412
#1413
#1414
Bobby
#1415
Hey! the smilies are back. They haven't worked for me in a while. And I bet some of you were glad.
I just got to my room in Richland, WA. It's been a long day. Maybe I'll get a chance to see Wayne while I'm here.
#1416
Well, it's easy enough to check and it's easy to polarize, so I'm not worried about that. Yet...
#1417
I've been thinking about this bent pulley on my generator for a while now. Ray said the sticker by the terminals looked like a rebuild sticker, and it probably is but I can't read it.
So the generator was rebuilt at some time in the past, and when that happened, they used the newer style '56 onward rear plate with the brushes attached. Thanks for that info 38 Coupe! That may be the only thing they did to it.
I bet after it was rebuilt, whoever was putting it back in the truck dropped it and bent the pulley. But, it worked, so they never tried to fix it.
Looking at the video I took of the new fan (thanks Ross) installed shows the wobble at the generator.
New Fan Video by JollyRogerJoe | Photobucket
#1418
On a side note... I was able to hook up with Wayne (52 Merc) tonight for a fine dinner. This kind of opportunity is one of the few things I like about traveling for a living. And that will be ending in just under 4 months. Thanks again Wayne!
Then the rest of you guys better watch out, because after I'm retired, I plan to look up a bunch more of you "old Ford" guys while traveling around the rest of the country.
On that note, my wife thinks we ought to get a big truck and car trailer to drag Betsy around the country. I'm one lucky guy...
#1419
http://www.columbiariverhighway.com/...er_highway.pdf
Historic Columbia River Highway
#1421
#1422
#1423
Now that I look more at the pictures of your generator, I think the whole generator is 1955. The back of the armature is smaller diameter to fit into the rear bearing; armatures going into bushings are larger diameter. The front and back plates include mounting ears. Originally H six cylinders used the same generator as the 8BA V8s. There was a separate bracket with a strap that held the original generator. Check out page 139 of the illustration section of the 48-56 Ford Truck Parts book (page 974 in the PDF). You can see the bracket and generator in this picture I found on Photobucket:
#1424
Stopped on at Multnomah Falls at least twice times on our trips back home from Wenatchee, WA. Last time we drove the narrow road (maybe it was US 30) and saw several other falls in the same area. I agree with Wayne, that drive is beautiful! A hike to the top of Multnomah is breathtaking, but we never had the time to do it.
#1425
