No breather vent in rear axle??
I own a 2003 Superduty. I was putting my boat in a lake with a real shallow launch so I had to back in until my back tires were completly under water. Afterwards I wanted to make sure the vent tube on my rear axle was long enough but I couldnt find it. Is there not a vent on my rear axle?
Time for a rear fluid change. Not even considering that the vent was underwater this time, how long has it been going without a vent tube, which could allow dirt, water spray from a wet road, whatever into the differential.
And you'll want to get a vent tube on there. If you look around, the original tube might be hanging around loose under there. It would have gone up to a open V shaped fitting connected up under the bed somewhere.
A hot diff soaked in cold water will pull a vacuum and potentially suck water in the disconnected diff. vent. You need to check/change it immediately, and possibly change it twice. Getting the diff good and hot with the new lube should drive off any remaining water, so I'd recommend a road trip after you change the oil.
Assuming it's a single rear wheel F-350.
75W-140 Synthetic Gear Oil and a friction modifier for the limited slip clutch pack.
Some companies (like Mobil 1) will make the oil with the friction modifier already in it. It should take about 3 1/2 quarts.
You'll also need some black silicone gasket maker, to seal the cover back up.
on
REAR AXLE
While you have the cover off, I would lift each side of the axle with a hydraulic jack under each shock mount 1 at a time for a few minutes. This is just in case water got into the axle tubes. If the rear end was under water for a few minutes, you might have quite a bit of water in there.
RON
I know this is old, but can't find much info on this topic.
My breather tube has fallen off the tee. I have the tube, however I can't figure out where to connect the Y fitting on the other end?
Somebody said it connects up under the body. Does anyone have a photo or know where this connects?
2002 F-250 5.4L
Thanks
2002 F-250 5.4L
Thanks
on
Know for sure the rear has a vent and almost sure the front does to but not 100% sure - vent is to allow gasses to escape as the oil in the pumpkin heats up - if they weren't vented the pinion seal would get blown out. (Ask me how I know - plugged vent on a 99 F150 + 150 miles @ 65mph = blown pinion seal and a diff soaked in gear oil)
