Limited Slip vs. Electronic Locking Differential
Old 08-01-2011, 10:33 AM
'89F2urd's Avatar
'89F2urd
'89F2urd is online now
i wouldnt get an ELD on my daily driver (and perhaps not even anything else). no salesman could ever convince me otherwise. (ELD + daily driver) = (bad idea)
Old 08-01-2011, 07:12 PM
atbear's Avatar
atbear
atbear is offline
Originally Posted by FORD FRED
atbear, your last question of which rear end ratio you should have is a good one that many people do not take into account especialy considering their individual situations. To actually give you the best advice on this matter I for one would need to know more about your situation. For one if you said which engine you wanted it got by me. Are you planning on putting bigger tires on it? Are most of your miles on the Interstate or on highways where you get to for the most part keep going with just the seldom red light or stop sign. Also city or town driving is a very relative thing. There is a very big difference in a 45 minute, 8 mile, 45 redlight trip across town on a daily basis for some and a 15 mile 23 minute trip thru or around town on a bypass that has 15 redlights but you generally only get caught at 5 of them. Having said all of that if you are going to get the 5.0 or the 3.5 eco a 3.55LS ratio is a good general purpose gear for the masses. I am like you in that I do not need a 4x4 but for me personally if I was getting a 3.5 eco I would get an XLT with the 3.15LS and keep the 17" wheels. For me in my pewrsonal stuation this would be ideal. But there are also many on here that should absolutrly be getting the 3.73LS becauce of how and where they drive. I am sorry for the long post but the BEST answer to your question would be based on facts not in evidence here yet.
Thanks. I will probably get the 3.5 EB. There's a chance I would get the 5.0L, but probably the EB.
As far as my driving, I live in the middle of Baton Rouge, so I drive mostly around the city, which has a lot of traffic. On a particular 10 mile commute, I might hit 7-10 red lights or stop signs. However, I also do a good bit of highway driving on Interstates. I usually travel 75-80mph on the Interstate. I don't tow very often. When I do, it's usually a 23' offshore boat (Boston Whaler).
Again, I'm not sure if I would get a 2WD or 4x4, and I know that's a big decision.
Old 08-01-2011, 07:13 PM
atbear's Avatar
atbear
atbear is offline
Why is that?
Old 08-03-2011, 06:45 AM
FORD FRED's Avatar
FORD FRED
FORD FRED is offline
atbear, I am posting here assuming that you will be keeping the standard size tires. Based on what you said and reading between the lines if I am correct most of the time when you get in your truck you will be driving a virtually empty truck in the city but most months you probably actually put more miles on the truck at 75-80 mph on the interstate. Also, I went to the Boston Whaler site and they currently have 3 models that could be your 23' boat which you rarely tow and these boat, motor, and trailer weights fully loaded would come in at 5000 to probably up to 6800 pounds. Also knowing how flat your part of the world is I would in the 3.5 eco 2wd recommend the 3.15LS rear end unless you insest on racing from red light to red light. This would get you around town just fine and be perfect for your interstate driving and still comfortably for your seldom and flat boat towing trips that I doubt are even as far as 200 miles perform well for you. If you get the 3.5 eco 4x4 I would get the 3.31 open axle for all of the same reasons. In the eco wether you go 2wd or 4x4 I would NOT go higher than the 3.55 axle ratio. If you choose the 5.0L engine then I would not consider anything other than the3.55LS 2wd or the 3.55 4X4. No matter what truck you buy you need the trailer tow package NOT the max tow package. And also get the factory trailer brake controler. Also you will need to pick up the after market trailer tow mirrors that just slip on over the factory mirrors for your rare boat towing trips. I suspect that your boat though very light weight for a boat this size is 8 1/2 feet wide. Remember that this is my 2 cents worth based on the available info and my reading between the lines. By the way, all Boston Whalers are very nice boats, I wish I was close enough to go out on it with you. I usually make it up to the DelMarVa peninsula every 2 to 3 years to go salt water fishing with my cousin. Good luck to you.
Old 08-03-2011, 07:00 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
I belive the opposite.
ELD is the best thing for a daily driver. Its an open rear end all the time unless you lock it in.
This means when my wife gets in my "new" Ecoboost powered truck, and makes a turn on a wet road, only the inside tire will spin allowing her to still drive in a straight line. Where as with a LSD, theres a chance the truck might spin on around and face the wrong way.
ELD is better in every instance, except for those that just want to pay a little less, or want to doughnuts in a parking lot with out hitting a button.
Old 08-03-2011, 02:32 PM
'89F2urd's Avatar
'89F2urd
i would have to agree with what youre saying, but i chose my words carefully. i said "my" daily. . .ELD's are just somethin else to go bad for somethin that will never need a locker. . . . .in addition, im always doin burnouts and drifts in my truck (wet or dry), so i couldnt stand an ELD.
i also prefer other-than-electric for my toys also, but thats another topic.
Old 08-03-2011, 03:59 PM
maverick22's Avatar
maverick22
maverick22 is offline
Originally Posted by 94MustangGT
A 4WD with a LS diff and 3.55's should suit you fine. I have the orginial traction lock diff in my '96 and it works fine with 165K miles on it. With the right tires, you should be able to go any sane place.
Right up until I got my 2005 F250 I would have agreed w/ you whole heartedly. I've got a '95 F150 w/ factory LS with 155,000miles and that thing still works great, as a matter of fact I've never been stuck in it. The '05 w/ factory LS and only 90,000miles? Not so much. I think Ford REALLY downgraded their LS's in that time frame. It hardly takes any torque to overcome the clutches in the '05 and it's back to 1 wheel peel. Seriously pathetic. The tires do suck on the '05 but I really don't think they're THAT bad.
For the OP, I wouldn't waste the money on Ford's LS and either go w/ the electric locker or an aftermarket LS or locker. Maybe they're different in the 150's or they've improved them since 2005 but personally I wouldn't waste the money.
Old 08-03-2011, 07:44 PM
atbear's Avatar
atbear
atbear is offline
Thanks. You pretty much nailed it. Half the time I'm in the city in stop and go traffic. Half the time I'm on the interstate doing 75-80mph. About a quarter of the weekends a year, I'm pulling the boat about 200 miles (round trip).
Something else to think about is how Ford's Traction Control now includes One-Wheel Spin Control as of 2011. It's basically an electronic Limited Slip system. Maybe you have seen some of the reports or videos about it?
Why would you recommend 3.15 for 2WD AND 3.55 for 4x4? What's the difference?
Old 08-03-2011, 07:59 PM
FORD FRED's Avatar
FORD FRED
atbear, in the eco 4x4 I recommended the 3.31 gear ratio. I can tell you that you you are towing more often than I originally thought. And if you are going to continue that practice I would actually suggest the 3.55 ratios are probably your best bet. I do not pretend to be on top of the traction control situation and I am trying to take a wait and see position on it. Good luck.
Old 08-03-2011, 11:06 PM
atbear's Avatar
atbear
atbear is offline
That's what I meant to write... 3.15 2WD vs. 3.31 4x4. Why the difference?
Old 08-04-2011, 03:41 AM
FORD FRED's Avatar
FORD FRED
atbear, In the 3.5L eco 2wd you choose from 3.15 - 3.55 - 3.73. In the 4x4 you choices are 3.31 - 3.55 - 3.73 and if I remember correctky the FX4 will let you get a 4.10 ratio although they seem to be rare and do not raise your towing capacity
Old 08-04-2011, 05:44 AM
tseekins's Avatar
tseekins
tseekins is online now
Received 1,219 Likes on 802 Posts
It does seem that ELD is not available on 4x2 trucks but it can be used in 2 wheel drive mode on the superduties. Not sure about the F-150.
Don't forget that these trucks come standard with traction control both 4x4 and 4x2. This is a nice feature to help reduce wheel spin and traction loss.
In the past I had an '86 4x4 with open diff and an '88 4x4 with LSD and I felt that they both performed the same off road.
  #28
Old 11-05-2014, 03:31 PM
SE Louisiana's Avatar
SE Louisiana
SE Louisiana is offline
Originally Posted by atbear
I'm trying to decide among 4x4, LS, or ELD.
Obviously 4x4 or 2WD is a choice on its own, and I'll need to make that decision.
However, I just want to make sure I understand the difference between LS and ELD. If I understand correctly, LS is different from an open differential in that it transfers the power to the rear wheel with the most traction rather than the wheel with the least resistance. ELD locks the differential up to 30mph (or sharp turns) so that both rear wheels get the same power at all times.
Is the ELD available in 2WD trucks? Before I knew about the ELD, I was deciding 4x4 or 2WD with LS. Now I'm thinking I might need to consider 4x4 or 2WD with ELD.
I won't be doing any serious mud riding, but I do go camping down muddy trails, pull boats up slick boat launches, and drive through wet grass often. Any opinions or suggestions?
I am now looking at a Ford F150 and am wondering if the LSD is a benefit to you at the Launch?
I Launch out of Pointe ala Hache area and the launch is part concrete and part dirt.
When I launch my friend's 23ft Fiberglass Bay Boat, I have a tough time with my 2wd Chevy Silverado when my wheels get to the dirt area. I do not have a problem with my 14ft flat aluminum boat.
Just wondering if the LSD would help in this area or if really need the 4x4 to get all the traction on this large boat.
Looks like you are in South La, so thought you may have real life experience with my concerns.
Any thoughts or suggestions welcomed!!!
  #29
Old 11-06-2014, 09:19 AM
Yeti Man's Avatar
Yeti Man
Yeti Man is offline
My 2014 F150 EB does indeed have the 4.10 ELD rearend; so it is available in 2wd.
  #30
Old 11-06-2014, 11:08 AM
conger's Avatar
conger
conger is offline
Why?
ELD's have been around for a long time. Same with vacuum lockers. ELD's just use a solenoid to lock it up inside of air pressure. Otherwise they behave like an open differential. LSD's have clutch packs that are always in use. They wear out usually somewhere around 60k and 80k miles and need to be replaced to recover good lock up control.
That said. The question about the boat ramp. How many times have we seen a boat ramp coat with moss and slime below the water line. So it seems to me to have a set of drive wheels up on dry land where there is some traction. As to axle ratio. If your towing, 3.55 or 3.73 will do the trick.
Quick Reply: Limited Slip vs. Electronic Locking Differential
