RTV, How long do you wait?
But anyway, by the time you get everything back together, you can fill it with coolant
If that dont seal it, there is something else wrong. The gasket is the sealer, the Hi-tack is just to hold it in place
The ONLY place RTV belongs on an engine is where the pan gasket meets the front/rear main and where the intake sits in the front and rear of the block. It belongs NO WHERE ELSE on an engine
I ONLY thing I use on gaskets for the past 20 years http://www.permatex.com/products/Aut...ve_Sealant.htm
not using a sealer on the water pump bolts is whats "wrong". whether its thread sealer, rtv, or something akin to either. . .its stupid not to use it. so, to say it has no use on a water pump swap is misleading, because it is perfectly acceptable as a thread sealer since its readily available in just 'bout every DIY'ers garage drawers. as far as the rest of your above said statement, that all depends on the motor thats bein built, and the condition its in.
They way I look at it is. IF the FACTORY didn't use it, neither will I.
i dont know how many water pums you have changed, but i have changed more than the number of cars people will own in a LIFETIME. and i have yet had one come back
With all due respect:
I know you don't technically have to use RTV. But I still do. Over time parts and surfaces change. They expand and contract get jostled up and down, etc. So naturally surfaces to be sealed may not necessarily be factory smooth. Bolts and threads change as well. If you change bolts, then you are changing other dynamics.
I don't know these things for a fact, but just applying some carefully thought out speculation. I would not change a thermostat without sealant! Sealant also expands and contracts helping seal water better in my opinion.
I too have done numerous car repairs over 30 + years, and can't recall a failure from using gasket sealant. I did not use sealant on my oil pan gasket as it is rubber.
I also like sealant to hold gaskets in place when mounting and assembling and tightening.
It is called thread sealant http://www.permatex.com/products/Aut...ad_Sealant.htm
go back and read what i said. i dont need links to thread sealer. . . . .
rtv is readily available in the diy's garage drawers, and is perfectly fine to use as a thread sealer. . . .
changing more pumps than the amount of cars someone will own in a lifetime, isnt saying very much.
redman84
20
01-18-2014 09:15 AM
