4X4 switch doesnt work , just switch or ?
Old 07-28-2011, 02:54 PM
Scruffy07Nav's Avatar
Scruffy07Nav
Scruffy07Nav is offline
My switch does not activate the 4x4 . I am thinking it's the switch because the none of the lights will even show up on the dash indicator, but I'm no genius on this stuff. Thanks in advance
Old 07-28-2011, 05:43 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
take a hammer and crawl underneath the Expy.
on the back of the transfer case there is a small motor. looks like a red-bull can.'
"lightly" tap on that motor with the hammer. start the Expy and shift into 4x4. This is a very common problem from the early 90's that seems to happen periodically even on these newer vehicles.
if that doesn't work, try checking the fuses for a blown one
Old 07-29-2011, 07:21 AM
Scruffy07Nav
I'll try at , already swapped the relay w/ another one didn't work Thanks !
Old 07-30-2011, 12:31 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
how did the hammer work?
if that did the trick, it's only a temp fix. The corrosion gets knocked loose by the tapping and the t-case will shift into 4x4 for a while. Then it will do it again.
a good preventative measure is to shift into 4x4 at least 1-2 times a month and drive around a bit. Gets things circulating and lubed up.
Old 07-30-2011, 12:38 PM
Scruffy07Nav
tapped on it yesterday pretty good and didn't work. So now I am not sure if its the switch or a module. I am sure its the most expensive item.
Smokey1961
1997 - 2003 F150
17
04-10-2023 09:56 AM
veritas
12-19-2008 08:48 AM
jayrus
06-23-2003 07:10 PM
duckleg
Bronco II
04-04-2003 09:15 PM
AdrianB
Bronco II
04-03-2002 08:54 PM
Quick Reply: 4X4 switch doesnt work , just switch or ?
