rear window wont roll down
First of all, welcome. Hope you enjoy this site as much as the rest us.
Common problem on the tailgate is that it may not be fully latched. Often if the striker posts are worn or for whatever reason the tailgate does not line up properly, the latches will not fully engage. There is an interlock switch on the driver's side latch that requires it to be fully engaged before the window can be lowered. The best suggestion is to try leaning on the gate while turning the keyswitch. There could be other problems but this is the best place to start. Once you get the window down you can open the gate.
Its an "either/or" situation. The switch on the dash and the keyswitch are redundant. They both do the same thing. They lower and raise the window. There is no "lock" so to speak on the tailgate. Having the window up makes getting the T-gate down virtually impossible....unless you opt to break the rear glass. (Long story)
im assuming that you cant hear the motor running,
if the switch upfront doent work then the window wont go down, to get it down i would get in the back of the truck and remove the accses panel once remove find the plug that goes into the moter and undo the wiring harnesses, then some how hook the wires to a 12 volt power sourse eather by the car battery or another type of battery, if it doesnt do anything reverse the the wires. and if the window still doesnt go down then you may need to unblot the motor in order it allow the window to go down then repalce the motor good luck to you
Fordluvr,
The keyswitch actually activates two seperate button switches inside the gate. If I listen carefully I can hear them click on mine. Sounds like they may be damaged or even missing on yours though. Might be a good time to invest in a manual with some wiring diagrams.
Welcome to the wonderful world of Bronco's and their tailgates!!! Depending on the shape of your tailgate and the amount of use you plan to give your window and gate, you might want to invest some $$ in a new gate and ward off some problems for the next few years. Trust me it can be very frustrating when you drop the window in the winter to haul something and then be forced to drive home in a snow storm with the window still open. I wont drop mine below a certain temp anymore. Good luck to you.
There's a safety switch on the driver's side latch inside the tailgate. If you remove the switch, simply short the two wires in the connector that previously connected to the switch. Two inches of wire and a couple of spade connectors should do the trick; it did on my '92. Do be aware that this now allows you to raise/lower the window regardless of whether the tailgate is up or down. Raising the window with the gate down may give you a few more square feet to set beers, but the window isn't that strong...
Had the same problem in my '91 XLT.What I finally did was to take the driver's side rear light cluster off.cut the ground,remove the connector and scrape down to bare metal.Reconnect the ground and spray over the area with a good primer (Coroless,from Eastwood).Haven't had a problem since doing that 3.5 years ago!Assuming you don't have a bad motor.
Sudsrat
Sudsrat
I have a 90 Bronco, had the same problem. IT turned out to be the cutout switch on the latch. I cut the connector and wire-nutted them together. I have had no problems since then. Though I found all this out after taking out the keyswitch and playing around with it, now I have no keyswitch to lower and raise it only the dash switch, but I make due. Other posts have offered the first step, find the power wires connector, should be the only one inside the tailgate near the motor. Disconnect it and run a long wire from each side of the battery to the two wires of the connector, motor should work if it is good. Then flip the wires and the motor should go the opposite direction. If this works, jump the interlock and try it with the dash or keyswitch. Good luck
John.
John.
