1998 f150 4.2 v6 rear end swap?
Old 07-26-2011, 07:14 AM
pulklogan's Avatar
pulklogan
pulklogan is offline
i have been looking around and i would like to swap my 8.8 to a 9". can i use any 9" or do i have to find one out of another 97-2001 i am also looking to get better gas milage is this posible?
Old 07-26-2011, 08:05 AM
phil6608's Avatar
phil6608
phil6608 is offline
For your year truck, they came with the 8.8 with the 4.2 and 4.6 motor.
The 5.4 came with a 9.75 and the F-250s and up came with a 10.25 rear.
Why do you need a bigger rear?
Old 07-26-2011, 08:48 AM
pulklogan's Avatar
pulklogan
i have herd that the 8.8 r weak i would like a 9" out of a mustang or something i would like better gas milage so by getting 9" i can change the gear ratio and get better gas milage. my truck is 2 wheel drive and i am very mechanically inclined so i can do all the work myself.
Old 07-26-2011, 09:33 AM
phil6608's Avatar
phil6608
phil6608 is offline
You have a 4.2 V6 with an 8.8
There is no way you could ever hurt that rear. Unless you put about 400 more HP in it.lol
Why not just change the gears in your current rear?
Old 07-26-2011, 09:35 AM
phil6608's Avatar
phil6608
phil6608 is offline
I know a guy that put a Lightning motor in his F-150 with an 8.8 rear in it and was running 12 second 1/4 miles with NO problem from the rear.
Old 07-27-2011, 07:38 AM
pulklogan's Avatar
pulklogan
ok thanks ill just stick with the 8.8 then i did not no that they r strong.
Old 01-22-2012, 09:48 PM
mudmattf150's Avatar
mudmattf150
mudmattf150 is offline
rearend
now i wana put a 9 inc in also but only fr tge possi rearend an because im puttin bigger tires on wat gears would be good in it so my v6 will still pus 37s good.an still got good torque
preppypyro
1997 - 2003 F150
05-07-2010 05:16 PM
Maineiac
13
02-19-2004 08:43 PM
twxsby
1983 - 2012 Ranger & B-Series
04-13-2003 11:26 PM
BBF250
1997 - 2003 F150
04-23-2002 09:31 AM
hotrodford_88
Performance & General Engine Building
08-17-2000 07:00 AM
Quick Reply: 1998 f150 4.2 v6 rear end swap?
