68 steering column
Old 07-25-2011, 04:44 PM
H00TY1's Avatar
H00TY1
H00TY1 is offline
68 steering column
hey guys, i have a 68 f100. I want to replace the steering column with one from the junk yard or ebay. It has power steering. I would like tilt and its an automatic. Which ones would be a direct fit? I have read in here that your installing from 71,73,77 even from a 83. Is that the way to go? I want cheap, no way paying the price for a new one..Please fill me in on easy way to go. thanks hooty1
Old 07-26-2011, 01:54 PM
mk's Avatar
mk
mk is offline
If you've got the saginaw p/s box, you can use any a/t p/s column from 68-79. Tilt was available only in '78/'79 and these fit also. If you've got a bendix p/s box (roughly same physical size as the manual box), I'd swap it for the saginaw box so you can use the newer columns. '80 and up columns won't fit without modification.
mike
Old 07-26-2011, 03:37 PM
H00TY1's Avatar
H00TY1
H00TY1 is offline
Hey thanks. That's a start. I have a Saginaw in there. Now just see if junkyard has what I need. They have a 71 on site. Just arrived.
Old 08-17-2011, 05:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Since the OP's truck is a 1968 F100...
1966/68 F100/250 2WD, 1969 F100/250 2WD before serial used Bendix P/S.
1969 F100/250 2WD & F350's from serial number D96,001, 1970/72 (and etc) F100/250 2WD & F350's used Ford (Saginaw) P/S.
P/S was not available for F350's before serial number D96,001.
Old 08-17-2011, 09:03 AM
killingmachine1's Avatar
killingmachine1
killingmachine1 is offline
ok then, could you use a 70 auto collum on a 75 ?
Old 08-17-2011, 11:25 PM
orich's Avatar
orich
orich is offline
mounting flange is not the same, But hey anything can be changed it you have a welder.
Old 08-19-2011, 08:24 AM
68murc's Avatar
68murc
68murc is offline
NOT TRYING TO HIJACK
I also have a steering column question about my 68'. I have a column from a 79' in there now, to fit with my 79' power steering box. I would like to go back to the 67-72 style column.....but I now have a B&M floor shifter.
I need a column that will fit with power steering and has no shift collar on the column. Is there such a thing?
Old 08-20-2011, 04:32 AM
jowilker's Avatar
jowilker
jowilker is offline
Since the firewall is basically the same steering columns from 65-79 will exchange. The spot weld cuff under the dash is deeper on the older trucks. One can use longer bolts or swap the cuff.
The big difference is that the Saginaw pump has the hose/tube connects on the top of the gear and require the column to be about 2 3/8" shorter, which most of the 73-79s are. The 70 column is most likely to be the longer of the two, and not a good candidate.
Bill ND can verify, I believe all you need to do is swap the cuff off the top of the column to one for a floor shift and you will have the smooth side.
John
Old 03-21-2013, 08:11 PM
reefmanchad's Avatar
reefmanchad
reefmanchad is offline
Hey y'all,I need a steering column for my 68 f100,want to get a chrome one,has manual steering,anyone know who would have one,found some on ebay,but would like more to look at,Thanks
Old 03-21-2013, 08:47 PM
70-360fe's Avatar
70-360fe
70-360fe is offline
80's mustang have a tilt without a shift column, don't know about the fit. I believe 80's bronco's also have tilt without shift on column.
Old 03-21-2013, 09:46 PM
mk's Avatar
mk
mk is offline
My first truck was a 72 F250 with ps/pb and 4 spd so I know those columns exist but sure don't see them very often. The 73-77 columns are almost exactly the same physically but have a different t/s switch, so that opens up your search a bit. I've got some columns and parts around here but sold my last 4 spd column head a few months ago. Another idea you could use comes from Muscle Car magazine's '409 on a dime' articles where they trimmed the shifter boss off the column and filled and reshaped it.
btw... thanks Bill, for the detail regarding bendix vs saginaw
mike
Old 03-22-2013, 05:52 AM
NumberDummy
C3DZ-3790-A (replaced FEK-3790-AP) .. Steering Column Extension-Takes the place of the shift collar when the shift lever is on the floor / Obsolete
1961/66 F100/250 2WD 4 speed / 1966 F100 4WD 4 speed / ALL 1967/77 F100/350 4 speed // 1962/66 Falcon/Comet 4 speed / 1963/64 Galaxie 4 speed / 1963/66 Fairlane 4 speed.
1965/66 Mustang (all A/T & M/T are floor shift) / 1965/66 Galaxie/LTD 4 speed w/o tilt wheel / 1968/69 Mustang/Cougar A/T & M/T w/o tilt wheel.
No one has any NOS, but 1,660,000 1965/66 Mustang's came with it, so it's not that hard to find used.
bmwcarl
WTB - Parts & other
06-13-2017 06:19 PM
themusicman
37
05-03-2015 03:08 PM
wallyworld
12-11-2014 01:51 PM
svolpone
23
04-01-2014 08:53 AM
BrotherMabe
13
02-03-2013 02:40 PM
Quick Reply: 68 steering column
