Sway bar bushing, clunk.
My local dealer, Superior Ford, couldn't find the clunk, and charged me $65 for looking. But I did, it is the right front sway bar bushing.
I have what must be the 1.25" (32mm) sway bar, and the bracket width is also about 1.25". At Rock Auto they don't list the width or it is 1.5" or 1.75". What do I need?
I don't know what part number you need. When I replaced mine I found it was just as cheap (with shipping) to buy them from the local dealer. And if they were wrong, it would have been a lot less hassle to return them. Turns out they gave me the right parts the first time.
And the next time you need something diagnosed, you should just send me a check for $65 and I'll post the question here and get you an actual answer instead of "we couldn't find anything".
I just bought a set of Energy suspension sway bar bushings for my dads 03' and installed them. If you have a 99'-04' SD these bushings will work. You will need a press to remove the stock bushings. Make sure you grease the new urethane bushings well with the supplied grease. I replaced the stock bolts and nuts with standard grade 10.9 metric nuts and bolts however that is optional.
Bought the bushing set from this guy
Energy Suspension Sway Bar-1 1/4" F-Series 99-04 | eBay
2004 F250 Sway Bar Bushing Replacement .: Articles
Install article from a FTE member
The OE Ford bushings I took off my dads 03' is Part#: 2034-5484-AA and they are 1 3/4" wide with a 1 1/4" ID. The strap that holds the bushing and bar in place is 1 1/4" wide like yours.
Any of the bushings on Rock Autos site that specifies for Front, 4wd, 1.250" bar from Moog or Raybestos should fit. I don't think all the "bracket width" and "bushing width" specs they list are accurate. They supposibly have a good customer service department, maybe give them a call.
Jermafenser
05-22-2015 04:43 PM
