Doesnt sound right to me
Just took my 2007 Expedition into my mechanice for a loud rattle coming from the front of the motor at every start up, a surging that to me feels like a misfire, and a lack of power. All have been getting worse. He told me it was 6 quarts low on oil. This car has hydraulic lifters, hydraulic cam, and hydraulic timing. Its always had oil pressure and no check engine lights. Ive even tried to pull history codes(Snap On scanner) and nothing. Being that low on oil the lifters should collapse and not open the valves timing would be screwed and the car shouldnt run at all. Someone please tell me if Im correct and being fed some BS.
The only thing I can think of is that the last guy to change my oil didnt put oil in the car. There are no signs of leaking and the truck doesnt smoke at all.
Hydraulic lifters- Nope the engine does not have any!!! Its SOHC and uses lash adjusters!
Hydraulic Cam-Nope that only comes into play with pushrod engines
Hydraulic timing-Yes it does have two cam phasers which could explain your surge!
The gauge in the dash is fake so do not go by that to judge oil pressure. It is preset to stay at the same mark as long as the sender gets 5 psi oil pressure.
The rattle on start up is the timing chain tensioners rattling from the gaskets being blown. You need to replace the tensioner gasket and arms. This is not from being low on oil. It is fairly common on the 5.4l motors and happened to mine at 50K and I change/check my oil regularly.
This was covered under my 5/60 power train warranty.
5.0stang
10-28-2007 11:09 AM
hoxiii
12-03-2006 09:28 AM
Frank
01-04-2000 02:51 AM
