Code U1900
Code U1900
I have a 2006 6.0L F250. I was pulling a trailer today with a small excavator on it down the highway at 70 mph and the wrench light came on. I have had this happen one other time hauling a trailer. I lerft the truck on this time and ran the DTC and got the U1900. What does this mean? What can i do to fix it? The truck misses at times at WOT, but does it randomly. But even when that hapens, the light doesnt come on and it doesnt go into limp mode. If you shut the truck off and start it again, it'll be back to normal... If that helps any
Possible Causes
CAN circuit 1908 (WH) open, short to ground, or short to voltage.
CAN circuit 1909 (BK) open, short to ground, or short to voltage.
DLC C251
ABS module
ABS module C135
instrument cluster
instrument cluster C220b
PCM
PCM C175b or C1381b
trailer brake controller
trailer brake controller C2142b
Things to check first:
You could have a bad ground on your trailer.
Your cable on your trailer could be too short and causing it to pull out of the plug
You could have a short in the factory trailer harness wiring
The plug could be gunked up
Also, check for loose fuses:
#11, 10 amp: Speedo bounce, ABS light, Cruise control inop; Codes U1900, U2023, P0500-P0503
#12, 2 amp: Cruise control inop, TBC Fault displayed, chime; Code C2803
DLC C251
ABS module
ABS module C135
instrument cluster
PCM
PCM C175b or C1381b
on
Sorry to undig a dead thread... since the beginning, I have gone through the top end with studs, and cleaned the turbo. The wrench light no longer comes on but on long hauls with a trailer, she sometimes likes to miss on the top end. Sometimes. Almost like it starves for fuel. Others, its perfectly fine. Fuel pressure is at 68 psi and stays there even at WOT and an sct tuner. Also have a AD2 and blue spring. Code is still there and my a/c no longer works... wonder if they are related in a way
I have a 2006 F250 6.0l lariat when i start it cold it smokes white until the engine is at operating temp. I just purchased this truck and it had a bully dog tuner on it. the truck would start but run very rough for a couple minutes and smoke white. I flashed the ecm back to stock and its only runs rough for a couple secs now but the smoke has gotten way worse. i am concerned that its a head gasket as i had to put 2, 4L jugs of antifreeze in it since i got it, it has a stored code u1900 i think many an ficm issue from the bully dog
nbimports
02-12-2017 09:08 AM
vrinner
01-20-2016 01:36 AM
