Idaho Chapter Idaho Chapter
Join Chapter, Leader:
Mustang help
Old 07-13-2011, 01:50 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
Mustang help
I have a 99 convertible and the top not closing correctly. When I close it the windows are on the outside of the top. The windows seam to be leaning out about a half an inch both sides. I am not sure if top caused the lean or if the window are causing the problem. I there a way to adjust the top? The windows? Does anyone know a a shop in Boise that works on the convertible top if this is something I can not do my self?
I posted on a mustang forum but never have had to good of luck getting back any help and I know all of you on this site are quick to help.
Thanks
Keith
Old 07-20-2011, 01:54 PM
im2tall33's Avatar
im2tall33
im2tall33 is offline
keith i cant help you man sorry but what i would recomend doing is posting it here General NON-Automotive Conversation - Ford Truck Enthusiasts Forums in the general auto forum and also pics would be very helpful as well..good luck man
Old 07-21-2011, 09:29 AM
luvemhot's Avatar
luvemhot
luvemhot is offline
Thanks I think I am getting it narrowed down. I will remember that part of the forum next time.
Old 07-29-2011, 04:58 PM
IDMooseMan's Avatar
IDMooseMan
IDMooseMan is offline
I'm assuming you have power windows, so here's my input.
Have you pulled the door panels to check if the glass has dislodged from the tracks? Have the tracks loosened up from their mounting points? Has the regulator become worn out? Sometimes the glass is held in by push-pins and other times they are bolted in. These points get worn out and / or loosen up. Bolts can be tightened, the push pins (plastic) need replacing if they're not part of the glass assembly.
We had a similar situation with my wife's Ford Contour. The driver-side window regulator had to be replaced several times before we traded in the Contour.
(Trouble submitting this reply. I hope it didn't double-post.)
Old 07-29-2011, 11:56 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
thanks moose man
ufvj217
1999 to 2016 Super Duty
07-22-2022 07:56 PM
F-150 MP
2004 - 2008 F150
07-30-2015 08:38 PM
jimford1
1978 - 1996 Big Bronco
16
02-12-2010 09:18 AM
Larry85355
04-14-2008 10:49 PM
RockyMtnRanger
03-06-2008 07:22 PM
Quick Reply: Mustang help
