Best performance parts for 351w?
I am looking to spend about $500 to $700 on performance parts for my 1996 f150 with a 5.8l and would just like some suggestions. what i'm looking for is h.p and torque gains, but a little more torque than h.p.. I am probably gonna buy summit racing shorty headers, over sized camshaft (I want it to lope), and get the heads port and polished. i just want the best bang for my buck and i don't know anything about mods for these trucks.
on
Adding 1.7 roller rockers and longtube headers will produce solid TQ gains on the cheap, if you do opt for a cam consider something like the comp 35-320-8 or Crane 444211 but be aware these cams may require upgraded valve springs as well because the stock springs can only handle a little over 0.500" lift. Head porting is wasted dollars IMO, unless you are doing it all yourself it will cost $500-$1000 to get something worthwhile and for that money you can have brand new heads that are far better. Instead look for a pair if GT40s from a '96-97.5 Explorer/Mountaineer, thay have larger valves and flow about 20% better than the stock E7s.
alright thanks guys. i was looking at gearing, thinking about 4.10:1 cause that is what the lightnings have. Good idea? And what are some cheap differential options? I have been looking for some gt40 heads, but i only thought they were on the lightnings, so that should help alot with finding some. I'm thinking right now gt40 heads, long tube headers, and a cam. Plus maybe an intake manifold if i can find something cheap enough but worth putting on.
I may be wrong, but I think your '96 should have a roller cam (?). The factory cam is not that terrible, and roller cams can be fairly pricey vs. the old flat tappet. I would start with a complete & quality tune-up w/ignition bump, a drop-in K&N filter, long tubes, a good dual exhaust and 1.7 rockers (if you have the money left over). 3.73 or 4.10 gears would also be a great "bang for the buck" upgrade. You can buy a set of FRPP gears for around $150 and plan on around another $200-$300 for install (unless you can set gears yourself). If the truck has some miles on it, I would also invest in new bearings. May be cheaper to find a complete used 3.73 rearend out of a salvage yard.
anyone here will tell you to leave the factory air box alone, the only better mod would be to get a snorkel from a junk yard from an i6 or 460 equipt truck that draws the air directly from behind the grill, a drop in k&n replacement filter that fits directly to your stock box is best
BrianBoru
02-07-2012 07:48 PM
Azguy54
16
11-01-2011 07:27 AM
chevyassasin
Performance & General Engine Building
10-10-2011 04:23 PM
1980 Ford F-250
04-16-2011 06:53 AM
