Motor Build
Wasn't that the motor that some poor fellow stateside had replaced, at stealer insistence, with pretty low mileage?
Then after the replacement motor also lost power under load the guy did some research himself and correctly figured out that the problem was a blocked in-tank strainer.
Thank you stealer, cost of new motor refunded, and for sale, one perfectly good 7.3 !
K. got the heads off
# 2 has a fair bit of pitting in it
all the rest look pretty clean.
heres a shot of the cylinders left to right 7,5,3,1
and left to right 2,4,6,8
common burn patttern. most will blame the tuner for the burn outside the bowl but I have seen a heap of stock motors with this. So go figure.
heres a shot of the lifter that belonged to the bent rod
and the other side
a bit of scoring but the lifter next to it looked the same. So so far there aint nothing that stands out ot me why it bent the rod (twice)
# 1 bore did have a distinct mark on it that the others didnt. Dont know if you can pick it up.
I can see what looks like a valve mark on the piston. But its the exhaust side. The intake is the one that keeps bending push rods
and the other side
The motor is a Ford reman which was still under warranty. I think their quality control has slipped somewhat in recent times.
Took it back in the next day to shove it up the backside of the guy that sold it to me.
I assume you plan on building this up and swapping out the motor you have currently?
