A/C wont change from defrost
Old 07-03-2011, 03:23 PM
jjdoyle's Avatar
jjdoyle
jjdoyle is offline
I have a 2005 ford excursion limited, 4X4 diesel. When I turn the A/C on it will only blow through the defrost vents (windshield and front windows). I push the other buttons to change the flow and get no response. I hear there is a vacuum actuater under the dash, any ideas
Old 07-03-2011, 11:08 PM
Swagtastic's Avatar
Swagtastic
Swagtastic is offline
You have a vacuum leak (95% likely) or a bad air blender (5% likely) Most common spots for vacuum leaks #1 somewhere in the 4WD lines. #2 whatever lines are exposed to the most heat or vibration. That may sound like generic advice but that's how it is, vacuum leaks are tied for the most irratating problem to figure out, oh yeah, electrical gremlins are the other tough one.
Old 07-03-2011, 11:23 PM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
I'd recommend checking out the 8th item on THIS PAGE for maintenance, and then getting some new lines for your ESOF system.
Old 07-04-2011, 10:07 PM
ScottyDsntKnow's Avatar
ScottyDsntKnow
ScottyDsntKnow is offline
This just happened on my Expy, if the Excursion is at all similar, there should be two lines going into the firewall right behind the battery. On my Expy, one of them was loose and actually open to air creating the exact condition you describe.
Old 07-05-2011, 10:34 PM
EX40's Avatar
EX40
EX40 is offline
I had this same problem on a '94 Mustang. I'd check the lines under hood 1st.
Old 07-06-2011, 03:19 AM
offroad_x's Avatar
offroad_x
offroad_x is offline
This has happened to me a couple of times. It was always a leak in the 4wd lines or hubs. To test the hubs just plug the vacuum lines going to the hubs (a golf tee works nicely) and see if your a/c vents start working.
jstihl
17
01-18-2016 09:25 AM
mshargrave23
09-15-2013 12:02 PM
99exp4wd5.4l
06-16-2012 04:52 AM
RollTideRoll
1999 to 2016 Super Duty
05-22-2011 03:33 PM
dep295
08-06-2008 06:11 PM
Quick Reply: A/C wont change from defrost
