1997 f150 4.6 overheating
Just tested with my new tester-3 times-ALL BLUE ALL THE TIME. Did notice the lower radiator hose collapsed (as well as the upper) while i was testing. Could it possibly be that the lower hose collapses the first time the t-stat opens because of the pump suction, causing my problem, then once the system has built up pressure from the heat, the lower stays open because of the pressure, hence no overheating till the engine is completely cooled off?
also the 180* T stat, is bit low...and may upset the running parameters a bit...run rich on cold starts. this may not be a real issue until colder weather hits, as it with run rich longer due to colder outside temps.
hadam
19
01-04-2016 12:00 PM
150, 1997, 46, 97, cylinder, engine, f150, ford, motor, overheat, overheated, overheating, overheats, thermostat, troubleshooting, truck
