2008 6.4 Turbo problems??
These engines have a serious lag or delay issue. Its in the programming due to the strict emissions requirements. From a dead stop if I give the truck anything more than 1/4 throttle it barely moves for about 2-4 seconds which seems like hours if trying to pull out in traffic. If I am slowing down and suddenly get back in it (again anything more than 1/4 throttle) the lag appears again.
I have found its not as bad when the engine isnt at operating temps yet. The more pedal you give it, the longer the delay.
If this is what you are experiencing its just the nature of the 6.4. Numerous complaints about it and I have been told by the dealer(s) that its normal. Actually they say they cant duplicate my concern, but take them for a ride and they recognize it but say its just normal.
I don't think it's lag. You could hold the pedal down for a solid 10-15 seconds and the turbo will never build up any pressure. Do that same thing 3-4 times then the turbo seems like it will kick in and start working again?????
Do you think it has something to do with the emission stuff or something?
I am new to these motors.
I think this is something else other than turbo lag. Do you ever get a cleaning exhaust filter message at all?
Do you have the screen to where you can run the setup and see MTE, brakes ok, battery ok and then at the end if it is in regen, see the message?
Also last time for fuel filter change?
[quote=senix;10500982]I think this is something else other than turbo lag. Do you ever get a cleaning exhaust filter message at all?
Also last time for fuel filter change?[/quote
This seems to be the right track, IMO. Filters, even if you or someone has changed them recently, I would do it again. I bought an early 08, and it seemed to have a bad lag, maybe not exactly the same time lag as the OP. I changed the fuel filters, replace with Motorcraft, and changed oil and used Motorcraft oil filter, drove it about 3K and did it again and the lag was far less noticable. Also, even thought the truck only had 25k on it, I put in a new Motorcraft Air Filter also, that seemed to help a lot also.
That sounds a lot more serious than the standard turbo lag. I have never seen it last 10-15 seconds.
I agree, you should start with the regular maintenance items as these trucks are really sensitive towards good maintenance. Be sure you replace BOTH fuel filters. As gearitis pointed out, do all the maintenance items so at least you know where you stand. When you buy used you either dont know or you are at the mercy of believing the person you purchased from.
Beyond that, look for trends. Is it weather related, temp of truck, long drives, short drives, anything you can pinpoint at all to establish a trend. Any smoke from the tailpipe? When was the last regen? etc.
I am not seeing anything about "exhaust filter cleaning or regen". I did have the warning come on to drain the water seperator so I did that and I also had my local shop put a new sensor on the water seperator. They were also supposed to put me 2 new fuel filters in but did not yesterday. I am going to take it back Monday and have them put 2 new fuel filters in and see if that helps.
I will let you know what happens after the 2 new fuel filters.
sounds like it is draining slow. So that means not only change the filters but inspect inside before putting new filters on.
Might want to consider a visit to the dealer for the kit for that cover where the yellow handle is.
You can take that cover off and clean in there as well once you get the kit.
Did you find the problem
Have same issue with my son in laws 2008 6.4, dealer diesel tech advised that I check VGT Duty Cycle as well as the TPS(Throttle Position) Actual and Desired. Torque Pro has these PIDS and can monitor I believe. Going to give that a try and see what it shows, then check back with dealer tech on results. They were 2-3 weeks out for scheduling so I asked him what I could do to possibly run it down and that is what he would check. Now I need to find out what Ford spec/resistance is on the TPS to see if I am in spec.
Let me know
