Competition Diesel racing, sleds, dynos, power tuning and max performance.
traction bars
Old 06-23-2011, 02:57 PM
brokeisnojoke's Avatar
brokeisnojoke
brokeisnojoke is offline
traction bars
Anyone know how to make front and rear traction bars the right way?
Old 07-02-2011, 12:11 PM
Riffraff Diesel's Avatar
Riffraff Diesel
Riffraff Diesel is online now
PREMIUM SPONSOR
On what vehicle?
Old 07-02-2011, 12:24 PM
brokeisnojoke
95 f250 psd extended cab long bed
Old 07-02-2011, 01:19 PM
Riffraff Diesel
PREMIUM SPONSOR
Talk to Dave at One-Up Offroad
Old 07-17-2011, 08:25 PM
powerstroke F350's Avatar
powerstroke F350
powerstroke F350 is offline
i dont know if it was the right way to build them but i just use a peice of angle iron bolted to the frame with square stock welded to the angle iron that goes back to the rear axel with flat bar welded to the square stock with 2 holes drilled in used a ubolt to bolt it to the axel this was on a 70 f250
Old 07-18-2011, 12:45 PM
patrickke's Avatar
patrickke
patrickke is offline
Is this truck lifted?
Old 07-18-2011, 01:08 PM
brokeisnojoke
Truck is not lifted my truck was supposed to be done for this season but had other crap go wrong. My rear hops bad so gonna put front and rear bars on it
Old 07-18-2011, 05:51 PM
Gus Erickson's Avatar
Gus Erickson
Gus Erickson is offline
What is your hitch height? Might be too low or you may need more tire pressure. I was running 55 to 60psi in the rear.
Old 07-18-2011, 08:59 PM
brokeisnojoke
My hitch hight is like 31 I do believe
Old 07-18-2011, 09:41 PM
patrickke's Avatar
patrickke
Like clay said look at the ouo bar there are a few others you could look at...
You may want to check out psa, psn, or comp d because there are quite a few pullers on those sites
Old 08-27-2011, 09:10 AM
TwinSkrewd's Avatar
TwinSkrewd
TwinSkrewd is offline
I'm sporting a set of Caltrec's on my F-150. Not sure what they offer for yours though. They can also custom build them to your specs. I started getting wheel hop when I switched over to M&H 28x11.5 slicks at the track.
Old 09-04-2011, 07:45 PM
patrickke's Avatar
patrickke
I love my caltracs they are cheap and really good quality
hwyhogg
23
11-24-2015 10:32 PM
defiantoutlaw
03-17-2014 11:14 PM
DHamSTER
12-05-2013 07:06 AM
trap4x4
04-16-2011 12:39 PM
shadow_almanza
03-02-2011 07:41 PM
Quick Reply: traction bars
