1985 f150 no power to starter solenoid?
Old 06-13-2011, 02:57 PM
moneypit79's Avatar
moneypit79
moneypit79 is offline
been working on a 85 f150 4wd. put in a rebuilt 351w. truck was turning over fine but i had a bad fuel pump. came back next day to try and start it and it wont do anything at the key switch.all accesories work and you can cross the solenoid and it will turn over. replaced solenoid same problem any ideas what to check before i put a damn p[ushbutton on this thing
Old 06-13-2011, 04:35 PM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
Does it have a neutral safety switch? What tranny?
Old 06-14-2011, 07:40 AM
Bully350's Avatar
Bully350
Bully350 is offline
Is it grounded correctly// had the same issue on my Farm tracter.. it kept giving me fits.. until i wire brushed behind the selenoit and but it back on with new bolt now perfect. I know we are talking trucks but if you have it at the starter post the ignition and battery but not from the big starter post is can be the ground.. if I am making any sence here...
Old 06-14-2011, 03:38 PM
guindian28's Avatar
guindian28
guindian28 is offline
check the ignition module
Lauraroka
04-18-2017 06:41 PM
66with352
1997 - 2003 F150
08-10-2016 12:51 PM
gtotiger65
06-21-2015 01:35 AM
nothercrash
03-10-2014 08:57 PM
Wooticus
06-16-2013 11:57 PM
Quick Reply: 1985 f150 no power to starter solenoid?
