Engine Size 1978 Ford F-150
Old 06-12-2011, 10:34 AM
Edy Stephens's Avatar
Edy Stephens
Edy Stephens is offline
I just bought a 1978 Ford F-150 and according to the Vin It has a 400 6.6L in it. How do I verify if this is the engine that is still in it?
Old 06-12-2011, 10:50 AM
Burburan's Avatar
Burburan
Burburan is offline
One way is to take the number off the block and google it. The engine block# should pop up as a Ford 400 engine if the engine hasn't been swaped out.
Old 06-12-2011, 10:53 AM
Edy Stephens
Where do I find the number? The plate on the front right side is missing.
Old 06-12-2011, 11:00 AM
Burburan's Avatar
Burburan
Burburan is offline
Check near the bell housing of the transmission, should be on the driver side. Look for user numbersdummy if you don't see it there, he should know.
Old 06-12-2011, 12:01 PM
Edy Stephens
Found two sets of numbers. One looks like 944; the other looks like an "S" on top, with a "-1" followed by a "c" or "s". Does this mean anything?
Old 06-12-2011, 12:36 PM
Burburan's Avatar
Burburan
Burburan is offline
Found out that if your block does not have one of these Block casting#'s then it is not a 400: D1AE-A, D1AE-C, D4AE-B2A, D7TE-A2B
Look for these Head casting numbers, they are for a 400 engine: D1AE, D4AE-AA, D5AE-A3A
Old 06-12-2011, 03:12 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
Can you post a picture of it? A 400 is pretty easy to spot, however it's almost impossible to visually distinguish from a 351M. Everything between the two motors is interchangeable except the crank and pistons, since they're the exact same engines, just different strokes. I'm not sure if it's possible to accurately measure the stroke in this case or not - otherwise the part number on the crankshaft would tell. This all assumes that the original valve cover sticker is gone - if not, then this is a no-brainer.
Old 06-12-2011, 03:18 PM
CraigOutdoors's Avatar
CraigOutdoors
CraigOutdoors is offline
If you pull a spark plug, stick a dowel into the cylinder and turn the crank, measure the stroke, the difference between the highest point and lowest point. If it's 4" it's a 400, if it's less, it's a 351M. That is, as long as the engine block is a 400/351M engine block and someone didn't swap in something different before you got it. Plus, if the valve covers are original, then one of them should have a label on it saying what it is.
Old 06-12-2011, 03:48 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Casting numbers on blocks are WORTHLESS for ID'ing the size of the engine or what vehicles it came from, ditto cylinder heads. Casting numbers are foundry marks only, cannot be cross referenced to Ford part numbers.
1977/79 F100/350 & 1978/79 Bronco: The same block casting numbers used on the 400 were also used on the 351M: D7TE-6015-AB, -A1B, -A2B.
351M/400's share the same bore (4.00"), the stroke is different. Stroke: 351M = 3.50" / 400 = 4.00"
It's almost impossible to tell a 351C from a 351M, or 400, because all look identical. Only the original carb and dizzy ID tag numbers are different.
Originally there was an engine ID tag bolted to the coil bracket, or intake manifold, but most of these are missing by now.
351C/351M/400: 8 valve cover bolt holes per side. There is no timing cover per se, just a flat plate.
The fuel pump bolts to the left (drivers) side of the block. Its bolt pattern is at 12 & 6 o'clock, the only fuel pumps to have this bolt pattern (all others are at 3 and 9 o'clock).
Old 06-12-2011, 04:19 PM
Edy Stephens
I want to buy some shorty exhaust manifolds but need to know what engine. Anyway simple way to figure out which ones to buy?
FOEngineer
New Hampshire Chapter
10-10-2016 12:49 PM
Chewy1978
09-22-2015 01:17 PM
joebane
12-26-2014 12:21 AM
1978fordmoneypit
04-06-2014 12:24 AM
Ole Green 1978
02-07-2012 12:02 PM
Quick Reply: Engine Size 1978 Ford F-150
