1997 f150 with 5.4l loss of power and mileage
Old 06-11-2011, 09:44 PM
93turbo's Avatar
93turbo
93turbo is offline
hey my 1997 f150 2wd with a 5.4l triton motor has 267,xxx miles on it. the only things that ever needed replaced were the alternator and coil packs. i put an insys usa intake on it and true dual 2.5" glasspacks. it ran great for about a month and i got between 18 and 20 mpg. and now it seems less snappy and i get 14mpg no matter what. this truck is crazy reliable and the frame and body are spotless. i need help on getting my economy and power back so i dont have to sell it. thanks
Old 06-11-2011, 11:35 PM
danger-ranger93's Avatar
danger-ranger93
danger-ranger93 is offline
Ever done the plugs on it? May want to do plugs if you haven't, and the seafoam treatment is very high up on my "recomend" list.
Old 06-12-2011, 06:27 AM
enriched&beyound's Avatar
enriched&beyound
enriched&beyound is offline
Have you tried to scan for codes?? sometimes there might be codes without the CEL
Have you cleaned the MAF sensor?
Have you checked for vacuum leaks?
Have you cleaned the throttle body?
Old 06-12-2011, 10:01 AM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
I would take that intake off, clean the MAF, and see if that doesn't take care of it. Not sure what kind of filter your new intake uses, but oil based filters are known to cause problems with MAF contamination.
Old 06-24-2011, 09:41 PM
93turbo's Avatar
93turbo
93turbo is offline
Plugs haven't been changed in a while only because they are a bear to change. MAF sensor is fine and the intake is spottless. My filter does not use oil. I was thinking more along the lines of plugged up cats but Idk.
Old 06-24-2011, 09:44 PM
93turbo's Avatar
93turbo
93turbo is offline
I also gave it a bottle of injector cleaner which helped a little
Old 06-24-2011, 11:09 PM
danger-ranger93
Plugs helped mine a TON. Yes, they were a pain in the *** but it needed to be done.
Old 06-25-2011, 11:24 AM
93turbo's Avatar
93turbo
93turbo is offline
yeah ill see about talking the old man into letting me do it again
Old 06-25-2011, 11:08 PM
danger-ranger93
Well, let me add some info here, mine had 259,*** miles on the originals.
fordinmudd
06-05-2016 10:46 PM
Tj Megan Rider
Modular V8 (4.6L, 5.4L)
12-01-2015 08:15 AM
shockr4
2004 - 2008 F150
22
02-13-2014 10:26 PM
abieleski
1997 - 2003 F150
06-24-2013 06:54 PM
mezcalero280cal
19
02-13-2012 07:23 PM
Quick Reply: 1997 f150 with 5.4l loss of power and mileage
