Oil changes
I don't use that monitor but do reset it after each oil change. Just change it based on miles. My first was at 1800, then will be around 5000 for now on. Use full synthetic oil, so I think 5000 is a good number. The manual does say 7500 with no towing and 5000 if you do tow.
On my old Chevy we would be able to get about 7000 miles before the oil life monitor said 0%, but never let it go that far.
Just did my 4th oil change, at 20k miles. Loving the 6.2L, use for towing and running around empty. Use Penzoil Ultra oil and motocraft filters.
I preset my oil minder to start at 60%, easy read the manual.. And pretty much the warning light comes on at about 5000 miles. Working great for me!
If you hit "Setup" a couple of times, you will get a message stating "Oil life 100%". However if you hit "Setup" immediately followed by "Reset" you will get a whole different set of readouts including the correct oil life %. After every oil change, go back to that screen and hit "Reset" once more and it will reset it back to 100%.
Sam
I'm not sure if you are reading it the right way.
Sam
Sam
Using bulk CP oil at work which is the same as the Motorcraft oil and with baseline UOA's on each new unit 91 in all! Average oil change according to the oil life monitor and UOA's its right about 7200 for all the trucks. All show very little wear metals and average less than a quart of make up oil between changes. We use CAT labs for our testing so all the trucks are now on a constant 7500 OCI. With a fleet this size that adds up to thousands of dollars saved and prevents waste of oil. We have 45 more trucks on order but the outfitter building them can't keep up! So far the 6.2 is working very well!!! By the end of this year we should have at least 20 trucks with over 100k on them! That will be the test!!! We get new trucks every 2 years and they are beaten and abused but well maintained and average about 150k when we dump them at auction. Fords are the only ones that have not fallen apart on us! I have very high hopes for this engine and look forward to great service from it!
billygoat
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-15-2007 01:12 PM
lost_sam
07-03-2004 11:18 PM
samckernan
02-25-2004 09:54 AM
