03 f150 xlt A/C blows out defrost
My 2003 f150 blows the a/c out the defrost when you give it gas when you let of the gas it goes back to the pannel.
I belive it is a vacume leak some where, I looked under hood, behind battery, and traced out everything I could find under the hood up to the firewall, where else should I check, I have the three ***** you turn for control is there something that fails where they are??
Please help
Please help
update
thanks for the info, I found the vacume leak right behind the battery, right where yall said it would be. A small section of solid line was all melted, I guess this happened when I left my battery cover off for a few months(this was stupid all it did was cas stuff to rust and corrode quickly from the extra battery gasses. Cover back on and leak fixed.
Thanks again.
Thanks again.
Holmesuser01
04-11-2014 07:51 AM
pickupman2002
09-24-2012 02:37 PM
05 f250 6 inch lift
09-15-2010 08:13 AM
