I've noticed a lot of used 2009-10s being purchased and many new owners are not getting the factory 5-digit keypad code with the truck (comes printed on a credit card with the owner's manual).
If you forget you can ask the dealer to hook up the computer and retrieve it (they cannot re-program the factory code).
Or you can locate the code under the passenger side kick panel:
I know on my brother 08 supercrew kingranch his was behind the rear seat on the drivers side. wasnt on the kick panel. Had to pull off the top of the rear seat to get to the liner and pull that away also to be able to read the code.
Yep, true of all 04-08s, all cab configs too IIRC. Changed in 09 to where Charlie described.
