P0113 - Intake Air Temp High... replace IAT?
Old 06-05-2011, 11:49 PM
43Duc's Avatar
43Duc
43Duc is offline
Hey guys, I'm getting the above code about once a month or so in my 2006 5.4. Is this something that I need to replace, or can I just pull the MAF and clean it? If replacement, is it possible to only replace the IAT, or do I have to replace the entire MAF?
For what it's worth, I'm running a KN filter (not cold air intake) and had run it for a year before the codes started popping up. I don't over-oil the filter, so I don't think it's an oil issue. I've got about 50k on the clock.
Am interested in hearing what you all think.
Also, I don't have a tech manual for my truck. Which of these is the MAF sensor:
-CB
Old 06-06-2011, 07:00 PM
Oldguy4's Avatar
Oldguy4
Oldguy4 is offline
Clean the MAF and the sensor, then loose the K&N. Just my opinion, but I've read on here and heard that any filter that gets oiled caused problems eventualy.
Old 06-06-2011, 07:53 PM
danorules's Avatar
danorules
danorules is offline
you should just clean the maf and throttle body . i clean them every oil change and dont have a problem running the k&n. it does get dirty between cleanings though, so im sure that has something to do with your problems.
Old 06-12-2011, 12:08 AM
43Duc's Avatar
43Duc
43Duc is offline
I took the module I labeled "A" in the picture above out to see about cleaning it. As far as I know that's the MAF and the IAT is integrated in that device. However, once I had it out I couldn't really see how to clean it. Any ideas? Did I take out the wrong thing?
Old 06-14-2011, 05:00 PM
COUNTRY0017's Avatar
COUNTRY0017
COUNTRY0017 is offline
HAD THIS HAPPEN ON MY WIFE'S TRUCK I JUST TOOK IT OUT AN SPRAYED CARB CLEANER ON IT AN USED A DENTAL PICK TO CLEAN IT BUT BE CAREFUL DON'T BE TO ROUGH WITH IT. JUST AN FYI I PUT A K@N FILTER IN HER TRUCK A MONTH BEFORE THIS HAPPENED.
Old 06-14-2011, 09:45 PM
Jr.Ranger-04's Avatar
Jr.Ranger-04
Jr.Ranger-04 is offline
Loose the K&N it is of no value....
JWA
29
07-01-2021 05:44 AM
JWA
28
02-01-2020 03:26 PM
86Stepside
15
09-11-2016 12:18 PM
t.r.c
1978 - 1996 Big Bronco
24
08-14-2016 11:03 PM
Quick Reply: P0113 - Intake Air Temp High... replace IAT?
