AC clutch not engaging need help!
Old 06-02-2011, 08:15 PM
tfs2403's Avatar
tfs2403
tfs2403 is offline
Hi all,
I need help trying toget my kids AC up and going for the summer.
92 F150 w/5.8.
With engine started, and the AC on "max or normal" setting the compressor clutch does not engage, not even an attempt.
I threw a meter on the wires/plug going to compressor and nothing, no 12 volts, no measured charge on the meter at all - (engine running A/c on).
Now, if you haven't already figured it out I know nothing about A/C systems.
I have checked fuzes, ect. and everything seems to be in order there. Where should I begin to search for the problem.
Thanks for any and all help.
Robb
Old 06-02-2011, 08:21 PM
dcarnut1's Avatar
dcarnut1
dcarnut1 is offline
If the system is low on refrigerant the clutch will not engage. You can bypass this by jumping the low pressure cut off switch. it is the switch mounted on the dryer (black cylinder on pass firewall). Disconnect the wireing harness and jump with a paper clip, clutch should engage.
Old 06-02-2011, 08:40 PM
tfs2403's Avatar
tfs2403
tfs2403 is offline
will give it a try, Thanks
Old 06-02-2011, 08:45 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
If it does kick in and run, don't run it long with the jumper. That switch is to protect the compressor when the freon is low..
Old 06-02-2011, 09:03 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
Have the system recovered and deep vac'd to check for a leak. The clutch isn't engaging for a reason, there isn't enough refrigerant in the system. If the low side pressure gets too low for an extended period of time the evaporator will freeze up, and the high side pressure will be out of control, possibly damaging the condenser or compressor. Don't try to rig it or anything, have it fixed correctly.
FWIW: being a '92, your truck originally came with R-12. Retrofit kits are available to convert to R-134a, however the oil and seals will need to be changed as they are not compatible.
Old 06-07-2011, 09:34 PM
tfs2403's Avatar
tfs2403
tfs2403 is offline
update
I did jump the plug and the clutch did engage. So what now? Do I need to take this in and have it all checked out by a pro or can I get this thing working with a little elbow grease of my own?
Thanks
Robb
Old 06-07-2011, 09:39 PM
octaneforce's Avatar
octaneforce
octaneforce is offline
my truck is a 92 and it called for r12, however i pumped it up with r134a and i havent had a problem. i got the little retrofit things that screw onto the low and high pressure ports. you can get the retrofit kit and pump it up with r134a at your own risk. like i said, mine works great, but others have not had the same luck. they make r12 substitutes i think. the last one ive heard of was freeze12. your most likely low on refrigerant.
Old 06-07-2011, 10:35 PM
dcarnut1's Avatar
dcarnut1
dcarnut1 is offline
Does the system have any pressure at all? With the compressor off the pressure will equalize across the system, should be around 150 psi.
If you have little or no pressure you have a leak in the system. just fixed one today that had a pinhole in the condensor discharge line.
Has the system been retrofitted? R12 system has small service ports with threads on the outside, R134 system has 2 different sized ports with threads on the inside. R12 systems used mineral oil for lubrication, R134 sytems use Pag oil. Mineral oil is not compatible with R134.
To work on the AC sytem you will need a set of ac gagues, Vacuum pump, refrigerent, seals, dye, etc. It is probably 6's to buy the tools or to pay a shop. If you plan to work on many vehicles, buy the tools. If this is the only vehicle you plan to work on, pay a pro.
Old 06-08-2011, 09:47 AM
hav24wheel's Avatar
hav24wheel
hav24wheel is offline
Retro fit kit, and a couple cans of R134, and a cheapy guage should do it. I've converted a couple vehicles and charged up with a single guage kit many times have had good luck.
Old 09-15-2011, 05:41 PM
blitzz66's Avatar
blitzz66
blitzz66 is offline
fuse blew now
did as suggested and the fuse blew clip melted in half so anyone know which fuse it might be because im not getting any air now ive checked all the fuses that have anything to do with ac and they are all good its a 2000 f350 7.3l
Old 09-15-2011, 06:13 PM
blitzz66's Avatar
blitzz66
blitzz66 is offline
well found it
well found it bypassing that low pressure switch and clutch still not kickn in any other suggestions
Old 09-15-2011, 06:23 PM
Bankrupter's Avatar
Bankrupter
Bankrupter is offline
Do you have power to the compressor ? I have seen a few that the wire is broken inside the compressor itself.
Old 09-15-2011, 06:37 PM
tfs2403's Avatar
tfs2403
tfs2403 is offline
update
Well I broke down and took it in to a shop. They found the compressor was bad, and there was a leak too. Due to other issues with the truck and the shop wanting over $500.00 to fix just the A/C we opted not to have it fixed. We are settling on 2/55 A/C (2 windows down, 55 mph)
Use the truck for a year or so and try to move up to something a little better shape.
THanks for the help guys I appreciate it!
Robb
Old 06-04-2016, 01:26 PM
Kimberlink's Avatar
Kimberlink
Kimberlink is offline
My 2001 f350 ac compressor clutch will not engage. I have voltage at compressor and it will engage if hooked to battery. Replaced connector for clutch. I have 35 lbs on low side when compressor jumped. Any suggestions I have also jumped high and low side switches. Need suggestions please
Netroamer
10-16-2021 12:26 PM
Infantryman1991
1999 to 2016 Super Duty
11-04-2017 01:55 PM
tractorboy924
07-13-2017 11:26 AM
tcjhkbjt
09-20-2016 06:33 PM
kountzecobra
02-22-2016 08:38 AM
Quick Reply: AC clutch not engaging need help!
