Transmission fluid...leaking?
Old 06-01-2011, 03:11 PM
Awitte58's Avatar
Awitte58
Awitte58 is offline
Drove to Kansas City Missouri for this past weekend.. made it there fine. cruised 70 highway.. (got 19.2mpg might i add). but when I came back and was unloadin in my driveway I had some nasty puddles under the truck.. The first puddle was rear diff fluid..it had rusted out. B
ut the front was a lot of trans fluid...kinda in a spray pattern but mostly directly under the truck.
No shifting problems... fluid level is still good.. so im keeping trans fluid in my tool box and driving to diagnose..
Drove today to work and around town some and back home. Enough to get it warm and get on it a bit up to 60 mph. Nothing spraying like yesterday...Not even a steady drip.
I guess ill have to wipe it all down and watch more closely?
Any ideas?
It did sit all from september till March or so.. but the seal shouldnt have dried up that quick? It was unloaded the entire trip..
Old 06-01-2011, 03:27 PM
texans's Avatar
texans
texans is offline
might be a bad front seal. Take off the inspection cover and see if there is trans fuild there.
Old 06-01-2011, 06:26 PM
bearhugger's Avatar
bearhugger
bearhugger is offline
i UNDERSTAND THAT THERE IS A VENT ON TOP OF THE TRANSMISSION,MAKE SURE IT IS NOT PLUGGED AND BUILDING UP PRESSURE IN THE TRANS.IF IT IS IT WILL BLOW OIL OUT THE SEAL.
Old 06-01-2011, 11:35 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Sounds like you got it hot and it boiled out a little. Put a cooler up front and get a guage.
Old 06-02-2011, 11:13 AM
RÖENTGEEP's Avatar
RÖENTGEEP
RÖENTGEEP is offline
FOREIGN GURU
Lightbulb
For that reason I was to ask if you had a tranny gauge. I agree with Glenn in this. Ill also would think to change the fluid because the heat.
Old 06-02-2011, 01:52 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
BIGRED 7.3L is offline
Are we talking Manual or Auto?
Old 06-03-2011, 08:53 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Awitte58 has an automatic, so we are talking Auto.
Old 06-03-2011, 09:02 AM
joe_13894's Avatar
joe_13894
joe_13894 is offline
If the front seal has never been changed it will start to leak hot. Then it will take less and less hot to get it to leak. When it leaks it REALLY DUMPS and then it will seal back up tight without a drip when it cools.
5 hours of work and $5 in parts to change it.
bobsplus
2017+ Super Duty
89
02-02-2018 11:18 AM
fordcrzymike
1997 - 2003 F150
06-27-2017 10:00 AM
Fordman96
1999 to 2016 Super Duty
05-24-2016 09:25 PM
kwozz48
03-02-2016 06:18 PM
Travis O'Connor
12-13-2015 05:58 PM
Quick Reply: Transmission fluid...leaking?
